OAR
RTEMS 4.5.0 On-Line Library
Non-Volatile Memory Driver Open a Particular Memory Partition
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
12.5: Open a Particular Memory Partition
This is the driver open call. Usually this call does nothing other than validate the minor number.
With some drivers, it may be necessary to allocate memory when a particular device is opened. If that is the case, then this is often the place to do this operation.
