OAR
RTEMS 4.5.0 On-Line Library
Non-Volatile Memory Driver Disable Read and Write Handlers
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
12.4: Disable Read and Write Handlers
Depending on the target's non-volatile memory configuration, it may be possible to write to a status register and make the memory area completely inaccessible. This is target dependent and beyond the standard capabilities of any memory type. The user has the optional capability to provide handlers to disable and enable access to a partiticular memory area.
