OAR
RTEMS 4.5.0 On-Line Library
Non-Volatile Memory Driver Initialize the Non-Volatile Memory Driver
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
12.3: Initialize the Non-Volatile Memory Driver
At system initialization, the non-volatile memory driver's initialization entry point will be invoked. As part of initialization, the driver will perform whatever initializatin is required on each non-volatile memory area.
The discrete I/O driver may register device names for memory partitions of particular interest to the system. Normally this will be restricted to the device "/dev/nv_memory" to indicate the entire device driver.
