OAR
RTEMS 4.5.0 On-Line Library
Non-Volatile Memory Driver Close a Particular Memory Partition
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
12.6: Close a Particular Memory Partition
This is the driver close call. Usually this call does nothing.
With some drivers, it may be necessary to allocate memory when a particular device is opened. If that is the case, then this is the place where that memory should be deallocated.
