OAR
RTEMS 4.5.0 On-Line Library
Initialization Code RTEMS Pretasking Callback
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
7.3.5: RTEMS Pretasking Callback
The pretasking_hook entry in the RTEMS CPU Configuration Table may be the address of a user provided routine that is invoked once RTEMS API initialization is complete but before interrupts and tasking are enabled. No tasks -- not even the IDLE task -- have been created when this hook is invoked. The pretasking hook is optional.
Although optional, most of the RTEMS BSPs provide a pretasking hook callback. This routine is usually called bsp_pretasking_hook and is found in the file:
c/src/lib/libbsp/CPU/BSP/startup/bspstart.c
The bsp_pretasking_hook() routine is the appropriate place to initialize any support components which depend on the RTEMS APIs. Most BSPs set the debug level for the system and initialize the RTEMS C Library support in their implementation of bsp_pretasking_hook(). This initialization includes the application heap used by the malloc family of routines as well as the reentrancy support for the C Library.
The routine bsp_libc_init routine invoked from the bsp_pretasking_hook() routine is passed the starting address, length, and growth amount passed to sbrk. This "sbrk amount" is only used if the heap runs out of memory. In this case, the RTEMS malloc implementation will invoked sbrk to obtain more memory. See Miscellaneous Support Files sbrk() Implementation for more details.
