OAR
RTEMS 4.5.0 On-Line Library
Initialization Code Board Initialization
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
7.3: Board Initialization
  • Initialization Code Start Code - Assembly Language Initialization
  • Initialization Code boot_card() - Boot the Card
  • Initialization Code bsp_start() - BSP Specific Initialization
  • Initialization Code main() - C Main
  • Initialization Code RTEMS Pretasking Callback
  • Initialization Code RTEMS Predriver Callback
  • Initialization Code Device Driver Initialization
  • Initialization Code RTEMS Postdriver Callback
  • This section describes the steps an application goes through from the time the first BSP code is executed until the first application task executes. The routines invoked during this will be discussed and their location in the RTEMS source tree pointed out.
