OAR
RTEMS 4.5.0 On-Line Library
Miscellaneous Support Files sbrk() Implementation
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
5.7: sbrk() Implementation
If the BSP wants to dynamically extend the heap used by the C Library memory allocation routines (i.e. malloc family), then this routine must be functional. The following is the prototype for this routine:
void * sbrk(size_t increment)
The increment amount is based upon the sbrk_amount parameter passed to the RTEMS_Malloc_Initialize during system initialization. See Initialization Code RTEMS Pretasking Callback for more information.
There is a default implementation which returns an error to indicate that the heap can not be extended. This implementation can be found in c/src/lib/libbsp/shared/sbrk.c. Many of the BSPs use this shared implementation. In order to use this implementation, the file Makefile.in in the BSP's startup directory must be modified so that the $VPATH variable searches both the startup directory and the shared directory. The following illustates the VPATH setting in the PowerPC psim BSP's startup/Makefile.in:
VPATH = @srcdir@:@srcdir@/../../../shared
This instructs make to look in all of the directories in the VPATH for the source files. The directories will be examined in the order they are specified.
