OAR
RTEMS 4.5.0 On-Line Library
User Extensions Manager Extensions
21.2.3: Extensions
  • User Extensions Manager TASK_CREATE Extension
  • User Extensions Manager TASK_START Extension
  • User Extensions Manager TASK_RESTART Extension
  • User Extensions Manager TASK_DELETE Extension
  • User Extensions Manager TASK_SWITCH Extension
  • User Extensions Manager TASK_BEGIN Extension
  • User Extensions Manager TASK_EXITTED Extension
  • User Extensions Manager FATAL Error Extension
  • The sections that follow will contain a description of each extension. Each section will contain a prototype of a function with the appropriate calling sequence for the corresponding extension. The names given for the Ada subprogram and its arguments are all defined by the user. The names used in the examples were arbitrarily chosen and impose no naming conventions on the user.
