The TASK_CREATE extension directly corresponds to the task_create directive. If this extension is defined in any static or dynamic extension set and a task is being created, then the extension routine will automatically be invoked by RTEMS. The extension should have a prototype similar to the following:
procedure User_Task_Create ( Current_Task : in RTEMS.TCB_Pointer; New_Task : in RTEMS.TCB_Pointer );
where current_task can be used to access the TCB for the currently executing task, and new_task can be used to access the TCB for the new task being created. This extension is invoked from the task_create directive after new_task has been completely initialized, but before it is placed on a ready TCB chain.
