OAR
RTEMS 4.5.0 On-Line Library
Partition Manager PARTITION_RETURN_BUFFER - Return buffer to a partition
13.4.5: PARTITION_RETURN_BUFFER - Return buffer to a partition
CALLING SEQUENCE:
procedure Partition_Return_Buffer (
   ID     : in     RTEMS.ID;
   Buffer : in     RTEMS.Address;
   Result :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - buffer returned successfully
RTEMS.INVALID_ID - invalid partition id
RTEMS.INVALID_ADDRESS - buffer address not in partition
DESCRIPTION:
This directive returns the buffer specified by buffer to the partition specified by id.
NOTES:
This directive will not cause the running task to be preempted.
Returning a buffer to a global partition which does not reside on the local node will generate a request telling the remote node to return the buffer to the specified partition.
