OAR
RTEMS 4.5.0 On-Line Library
Partition Manager Directives
13.4: Directives
  • Partition Manager PARTITION_CREATE - Create a partition
  • Partition Manager PARTITION_IDENT - Get ID of a partition
  • Partition Manager PARTITION_DELETE - Delete a partition
  • Partition Manager PARTITION_GET_BUFFER - Get buffer from a partition
  • Partition Manager PARTITION_RETURN_BUFFER - Return buffer to a partition
  • This section details the partition manager's directives. A subsection is dedicated to each of this manager's directives and describes the calling sequence, related constants, usage, and status codes.
