OAR
RTEMS 4.5.0 On-Line Library
Partition Manager PARTITION_GET_BUFFER - Get buffer from a partition
13.4.4: PARTITION_GET_BUFFER - Get buffer from a partition
CALLING SEQUENCE:
procedure Partition_Get_Buffer (
   ID     : in     RTEMS.ID;
   Buffer :    out RTEMS.Address;
   Result :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - buffer obtained successfully
RTEMS.INVALID_ID - invalid partition id
RTEMS.UNSATISFIED - all buffers are allocated
DESCRIPTION:
This directive allows a buffer to be obtained from the partition specified in id. The address of the allocated buffer is returned in buffer.
NOTES:
This directive will not cause the running task to be preempted.
All buffers begin on a four byte boundary.
A task cannot wait on a buffer to become available.
Getting a buffer from a global partition which does not reside on the local node will generate a request telling the remote node to allocate a buffer from the specified partition.
