RTEMS Logo
RTEMS 4.10.1 On-Line Library
Process Environment Manager Directives
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
3.4: Directives
  • Process Environment Manager getpid - Get Process ID
  • Process Environment Manager getppid - Get Parent Process ID
  • Process Environment Manager getuid - Get User ID
  • Process Environment Manager geteuid - Get Effective User ID
  • Process Environment Manager getgid - Get Real Group ID
  • Process Environment Manager getegid - Get Effective Group ID
  • Process Environment Manager setuid - Set User ID
  • Process Environment Manager setgid - Set Group ID
  • Process Environment Manager getgroups - Get Supplementary Group IDs
  • Process Environment Manager getlogin - Get User Name
  • Process Environment Manager getlogin_r - Reentrant Get User Name
  • Process Environment Manager getpgrp - Get Process Group ID
  • Process Environment Manager setsid - Create Session and Set Process Group ID
  • Process Environment Manager setpgid - Set Process Group ID for Job Control
  • Process Environment Manager uname - Get System Name
  • Process Environment Manager times - Get process times
  • Process Environment Manager getenv - Get Environment Variables
  • Process Environment Manager setenv - Set Environment Variables
  • Process Environment Manager ctermid - Generate Terminal Pathname
  • Process Environment Manager ttyname - Determine Terminal Device Name
  • Process Environment Manager ttyname_r - Reentrant Determine Terminal Device Name
  • Process Environment Manager isatty - Determine if File Descriptor is Terminal
  • Process Environment Manager sysconf - Get Configurable System Variables
  • This section details the process environment manager's directives. A subsection is dedicated to each of this manager's directives and describes the calling sequence, related constants, usage, and status codes.
