RTEMS Logo
RTEMS 4.10.1 On-Line Library
Process Environment Manager setenv - Set Environment Variables
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
3.4.18: setenv - Set Environment Variables
CALLING SEQUENCE:
int setenv(
  const char *name,
  const char *value,
  int overwrite
STATUS CODES:
Returns 0 if successful and -1 otherwise.
DESCRIPTION:
This service adds the variable name to the environment with value. If name is not already exist, then it is created. If name exists and overwrite is zero, then the previous value is not overwritten.
NOTES:
NONE
