RTEMS Logo
RTEMS 4.10.1 On-Line Library
Process Environment Manager ttyname - Determine Terminal Device Name
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
3.4.20: ttyname - Determine Terminal Device Name
CALLING SEQUENCE:
char *ttyname(
  int fd
STATUS CODES:
Pointer to a string containing the terminal device name or NULL is returned on any error.
DESCRIPTION:
This service returns a pointer to the pathname of the terminal device that is open on the file descriptor fd. If fd is not a valid descriptor for a terminal device, then NULL is returned.
NOTES:
This routine uses a static buffer.
