RTEMS Logo
RTEMS 4.10.1 On-Line Library
Object Services Directives
PREV UP NEXT Bookshelf RTEMS C User's Guide
27.4: Directives
  • Object Services BUILD_NAME - Build object name from characters
  • Object Services OBJECT_GET_CLASSIC_NAME - Lookup name from id
  • Object Services OBJECT_GET_NAME - Obtain object name as string
  • Object Services OBJECT_SET_NAME - Set object name
  • Object Services OBJECT_ID_GET_API - Obtain API from Id
  • Object Services OBJECT_ID_GET_CLASS - Obtain Class from Id
  • Object Services OBJECT_ID_GET_NODE - Obtain Node from Id
  • Object Services OBJECT_ID_GET_INDEX - Obtain Index from Id
  • Object Services BUILD_ID - Build Object Id From Components
  • Object Services OBJECT_ID_API_MINIMUM - Obtain Minimum API Value
  • Object Services OBJECT_ID_API_MAXIMUM - Obtain Maximum API Value
  • Object Services OBJECT_API_MINIMUM_CLASS - Obtain Minimum Class Value
  • Object Services OBJECT_API_MAXIMUM_CLASS - Obtain Maximum Class Value
  • Object Services OBJECT_GET_API_NAME - Obtain API Name
  • Object Services OBJECT_GET_API_CLASS_NAME - Obtain Class Name
  • Object Services OBJECT_GET_CLASS_INFORMATION - Obtain Class Information
  • PREV UP NEXT Bookshelf RTEMS C User's Guide
