RTEMS Logo
RTEMS 4.10.1 On-Line Library
Object Services OBJECT_ID_API_MINIMUM - Obtain Minimum API Value
PREV UP NEXT Bookshelf RTEMS C User's Guide
27.4.10: OBJECT_ID_API_MINIMUM - Obtain Minimum API Value
CALLING SEQUENCE:
int rtems_object_id_api_minimum(void);
DIRECTIVE STATUS CODES
Returns the minimum valid for the API portion of an object Id.
DESCRIPTION:
This service returns the minimum valid for the API portion of an object Id.
NOTES:
This directive is strictly local and does not impact task scheduling.
