RTEMS Logo
RTEMS 4.10.1 On-Line Library
Object Services OBJECT_API_MAXIMUM_CLASS - Obtain Maximum Class Value
PREV UP NEXT Bookshelf RTEMS C User's Guide
27.4.13: OBJECT_API_MAXIMUM_CLASS - Obtain Maximum Class Value
CALLING SEQUENCE:
int rtems_object_api_maximum_class(
  int api
DIRECTIVE STATUS CODES
If api is not valid, -1 is returned.
If successful, this service returns the maximum valid for the class portion of an object Id for the specified api.
DESCRIPTION:
This service returns the maximum valid for the class portion of an object Id for the specified api.
NOTES:
This directive is strictly local and does not impact task scheduling.
