RTEMS Logo
RTEMS 4.10.0 On-Line Library
Insure GCC and GNAT Environment Variables Are Not Set
PREV UP NEXT Bookshelf Getting Started with GNAT/RTEMS
2.1.1.2: Insure GCC and GNAT Environment Variables Are Not Set
If any of the following commands produce output, then you have environment variables overriding the default behavior of the native GNAT toolset. These variables will conflict with the cross toolset. Please resolve this problem before proceeding further.
echo $GCC_EXEC_PREFIX
echo $ADA_INCLUDE_PATH
echo $ADA_OBJECTS_PATH
echo $LD_RUN_PATH
echo $C_INCLUDE_PATH
