Getting Started with GNAT/RTEMS
Place the following Ada source code in hello.adb:
with Text_IO; use Text_IO; procedure Hello is begin Put_Line ( "Hello World"); end Hello;
Use the following command sequence to ompile and execute the above program:
gnatmake hello ./hello
If the message Hello World
is printed, then the native installation
of GNAT operates well enough to proceed.
