RTEMS Logo
RTEMS 4.10.0 On-Line Library
Verifying Correct Operation of Native GNAT
PREV UP NEXT Bookshelf Getting Started with GNAT/RTEMS
2.1.1: Verifying Correct Operation of Native GNAT
  • Native Hello World Test
  • Insure GCC and GNAT Environment Variables Are Not Set
  • It is imperative that the native GNAT installation work correctly for the installation of GNAT/RTEMS to succeed. It is recommended that the user verify that the native GNAT is installed correctly by performing these tests:
