RTEMS Logo
RTEMS 4.10.0 On-Line Library
Object Services OBJECT_ID_API_MAXIMUM - Obtain Maximum API Value
27.4.11: OBJECT_ID_API_MAXIMUM - Obtain Maximum API Value
CALLING SEQUENCE:
function Object_Id_API_Maximum return RTEMS.Unsigned32;
DIRECTIVE STATUS CODES
Returns the maximum valid for the API portion of an object Id.
DESCRIPTION:
This service returns the maximum valid for the API portion of an object Id.
NOTES:
This directive is strictly local and does not impact task scheduling.
