RTEMS Logo
RTEMS 4.10.0 On-Line Library
Object Services OBJECT_API_MINIMUM_CLASS - Obtain Minimum Class Value
27.4.12: OBJECT_API_MINIMUM_CLASS - Obtain Minimum Class Value
CALLING SEQUENCE:
procedure Object_API_Minimum_Class(
   API     : in     RTEMS.Unsigned32;
   Minimum :    out RTEMS.Unsigned32
DIRECTIVE STATUS CODES
If api is not valid, -1 is returned.
If successful, this service returns the minimum valid for the class portion of an object Id for the specified api.
DESCRIPTION:
This service returns the minimum valid for the class portion of an object Id for the specified api.
NOTES:
This directive is strictly local and does not impact task scheduling.
