RTEMS Logo
RTEMS 4.10.0 On-Line Library
Object Services OBJECT_ID_API_MINIMUM - Obtain Minimum API Value
27.4.10: OBJECT_ID_API_MINIMUM - Obtain Minimum API Value
CALLING SEQUENCE:
function Object_Id_API_Minimum return RTEMS.Unsigned32;
DIRECTIVE STATUS CODES
Returns the minimum valid for the API portion of an object Id.
DESCRIPTION:
This service returns the minimum valid for the API portion of an object Id.
NOTES:
This directive is strictly local and does not impact task scheduling.
