RTEMS Logo
RTEMS 4.10.0 On-Line Library
Object Services BUILD_ID - Build Object Id From Components
27.4.9: BUILD_ID - Build Object Id From Components
CALLING SEQUENCE:
function Build_Id(
   the_api   : in     RTEMS.Unsigned32;
   the_class : in     RTEMS.Unsigned32;
   the_node  : in     RTEMS.Unsigned32;
   the_index : in     RTEMS.Unsigned32
) return RTEMS.Id;
DIRECTIVE STATUS CODES
Returns an object Id constructed from the provided arguments.
DESCRIPTION:
This service constructs an object Id from the provided the_api, the_class, the_node, and the_index.
NOTES:
This directive is strictly local and does not impact task scheduling.
This directive does NOT validate the arguments provided or the Object id returned.
