RTEMS Logo
RTEMS 4.10.0 On-Line Library
Object Services OBJECT_ID_GET_INDEX - Obtain Index from Id
27.4.8: OBJECT_ID_GET_INDEX - Obtain Index from Id
CALLING SEQUENCE:
procedure Object_Id_Get_Index(
   ID    : in     RTEMS.ID;
   Index :    out RTEMS.Unsigned32
DIRECTIVE STATUS CODES
Returns the index portion of the object Id.
DESCRIPTION:
This directive returns the index portion of the provided object id.
NOTES:
This directive is strictly local and does not impact task scheduling.
This directive does NOT validate the id provided.
