RTEMS Logo
RTEMS 4.10.0 On-Line Library
Rate Monotonic Manager RATE_MONOTONIC_GET_STATISTICS - Obtain statistics from a period
19.4.7: RATE_MONOTONIC_GET_STATISTICS - Obtain statistics from a period
CALLING SEQUENCE:
NOT SUPPORTED FROM Ada BINDING
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - period initiated successfully
RTEMS.INVALID_ID - invalid rate monotonic period id
RTEMS.INVALID_ADDRESS - invalid address of statistics
DESCRIPTION:
This directive returns statistics information associated with the rate monotonic period id in the following data record:
This directive returns the current statistics information for the period instance assocaited with id. The information returned is indicated by the structure above.
NOTES:
This directive will not cause the running task to be preempted.
