procedure Rate_Monotonic_Reset_Statistics ( ID : in RTEMS.ID; Result : out RTEMS.Status_Codes );
RTEMS.SUCCESSFUL - period initiated successfully
RTEMS.INVALID_ID - invalid rate monotonic period id
This directive resets the statistics information associated with this rate monotonic period instance.
This directive will not cause the running task to be preempted.
