RTEMS Logo
RTEMS 4.10.0 On-Line Library
Timer Manager TIMER_FIRE_AFTER - Fire timer after interval
8.4.5: TIMER_FIRE_AFTER - Fire timer after interval
CALLING SEQUENCE:
procedure Timer_Fire_After (
   ID        : in     RTEMS.ID;
   Ticks     : in     RTEMS.Interval;
   Routine   : in     RTEMS.Timer_Service_Routine;
   User_Data : in     RTEMS.Address;
   Result    :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - timer initiated successfully
RTEMS.INVALID_ADDRESS - routine is NULL
RTEMS.INVALID_ID - invalid timer id
RTEMS.INVALID_NUMBER - invalid interval
DESCRIPTION:
This directive initiates the timer specified by id. If the timer is running, it is automatically canceled before being initiated. The timer is scheduled to fire after an interval ticks clock ticks has passed. When the timer fires, the timer service routine routine will be invoked with the argument user_data.
NOTES:
This directive will not cause the running task to be preempted.
