RTEMS Logo
RTEMS 4.10.0 On-Line Library
Timer Manager TIMER_DELETE - Delete a timer
8.4.4: TIMER_DELETE - Delete a timer
CALLING SEQUENCE:
procedure Timer_Delete (
   ID     : in     RTEMS.ID;
   Result :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - timer deleted successfully
RTEMS.INVALID_ID - invalid timer id
DESCRIPTION:
This directive deletes the timer specified by id. If the timer is running, it is automatically canceled. The TMCB for the deleted timer is reclaimed by RTEMS.
NOTES:
This directive will not cause the running task to be preempted.
A timer can be deleted by a task other than the task which created the timer.
