RTEMS 4.10.0 On-Line Library
Timer Manager Directives
RTEMS Ada User's Guide
8.4: Directives
Timer Manager TIMER_CREATE - Create a timer
Timer Manager TIMER_IDENT - Get ID of a timer
Timer Manager TIMER_CANCEL - Cancel a timer
Timer Manager TIMER_DELETE - Delete a timer
Timer Manager TIMER_FIRE_AFTER - Fire timer after interval
Timer Manager TIMER_FIRE_WHEN - Fire timer when specified
Timer Manager TIMER_INITIATE_SERVER - Initiate server for task-based timers
Timer Manager TIMER_SERVER_FIRE_AFTER - Fire task-based timer after interval
Timer Manager TIMER_SERVER_FIRE_WHEN - Fire task-based timer when specified
Timer Manager TIMER_RESET - Reset an interval timer
This section details the timer manager's directives.
A subsection is dedicated to each of this manager's directives
and describes the calling sequence, related constants, usage,
and status codes.
