RTEMS Logo
RTEMS 4.7.99.2 On-Line Library
Texas Instruments C3x/C4x Specific Information Flat Memory Model
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
9.3.2: Flat Memory Model
XXX check actual bits on the various processor families.
The XXX family supports a flat 32-bit address space with addresses ranging from 0x00000000 to 0xFFFFFFFF (4 gigabytes). Each address is represented by a 32-bit value and is byte addressable. The address may be used to reference a single byte, word (2-bytes), or long word (4 bytes). Memory accesses within this address space are performed in big endian fashion by the processors in this family.
