RTEMS Logo
RTEMS 4.7.99.2 On-Line Library
MIPS Specific Information Interrupt Processing
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
5.4: Interrupt Processing
  • MIPS Specific Information Vectoring of an Interrupt Handler
  • MIPS Specific Information Interrupt Levels
  • MIPS Specific Information Disabling of Interrupts by RTEMS
  • MIPS Specific Information Interrupt Stack
  • Different types of processors respond to the occurrence of an interrupt in its own unique fashion. In addition, each processor type provides a control mechanism to allow for the proper handling of an interrupt. The processor dependent response to the interrupt modifies the current execution state and results in a change in the execution stream. Most processors require that an interrupt handler utilize some special control mechanisms to return to the normal processing stream. Although RTEMS hides many of the processor dependent details of interrupt processing, it is important to understand how the RTEMS interrupt manager is mapped onto the processor's unique architecture. Discussed in this chapter are the XXX's interrupt response and control mechanisms as they pertain to RTEMS.
