RTEMS Logo
RTEMS 4.6.99.3 On-Line Library
Analog Driver Analog Driver Configuration
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
17.2: Analog Driver Configuration
There is not a standard analog driver configuration table but some fields are common across different drivers. The analog driver configuration table is typically an array of structures with each structure containing the information for a particular board. The following is a list of the type of information normally required to configure an analog board:
board_offset
is the base address of a board.
DAC_initial_values
is an array of the voltages that should be written to each DAC during initialization. This allows the driver to start the board in a known state.
