RTEMS Logo
RTEMS 4.6.99.3 On-Line Library
Analog Driver Major and Minor Numbers
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
17.1: Major and Minor Numbers
The major number of a device driver is its index in the RTEMS Device Address Table.
A minor number is associated with each device instance managed by a particular device driver. An RTEMS minor number is an unsigned32 entity. Convention calls dividing the bits in the minor number down into categories like the following:
From the above, it should be clear that a single device driver can support multiple copies of the same board in a single system. The minor number is used to distinguish the devices.
