procedure Task_Wake_After ( Ticks : in RTEMS.Interval; Result : out RTEMS.Status_Codes );
RTEMS.SUCCESSFUL - always successful
This directive blocks the calling task for the specified number
of system clock ticks. When the requested interval has elapsed,
the task is made ready. The rtems.clock_tick
directive automatically updates the delay period.
Setting the system date and time with the
rtems.clock_set directive
has no effect on a rtems.task_wake_after blocked task.
A task may give up the processor and remain in the ready state
by specifying a value of RTEMS.YIELD_PROCESSOR in ticks.
The maximum timer interval that can be specified is the maximum value which can be represented by the rtems_unsigned32 type.
A clock tick is required to support the functionality of this directive.
Copyright © 1988-2003 OAR Corporation
