RTEMS 4.6.0pre5 On-Line Library
Task Manager Directives
RTEMS Ada User's Guide
5.4: Directives
Task Manager TASK_CREATE - Create a task
Task Manager TASK_IDENT - Get ID of a task
Task Manager TASK_START - Start a task
Task Manager TASK_RESTART - Restart a task
Task Manager TASK_DELETE - Delete a task
Task Manager TASK_SUSPEND - Suspend a task
Task Manager TASK_RESUME - Resume a task
Task Manager TASK_IS_SUSPENDED - Determine if a task is Suspended
Task Manager TASK_SET_PRIORITY - Set task priority
Task Manager TASK_MODE - Change the current task mode
Task Manager TASK_GET_NOTE - Get task notepad entry
Task Manager TASK_SET_NOTE - Set task notepad entry
Task Manager TASK_WAKE_AFTER - Wake up after interval
Task Manager TASK_WAKE_WHEN - Wake up when specified
Task Manager TASK_VARIABLE_ADD - Associate per task variable
Task Manager TASK_VARIABLE_GET - Obtain value of a per task variable
Task Manager TASK_VARIABLE_DELETE - Remove per task variable
This section details the task manager's directives. A
subsection is dedicated to each of this manager's directives and
describes the calling sequence, related constants, usage, and
status codes.
Copyright © 1988-2003 OAR Corporation
