This defines the per CPU state information required by RTEMS and the BSP.
More...
| file | percpu.c |
| | Allocate and Initialize Per CPU Structures.
| #define | _Per_CPU_Acquire(cpu) |
| #define | _Per_CPU_Release(cpu) |
| #define | _Per_CPU_ISR_disable_and_acquire(cpu, isr_cookie) |
| #define | _Per_CPU_Release_and_ISR_enable(cpu, isr_cookie) |
#define | _Per_CPU_Acquire_all(isr_cookie) _ISR_Disable( isr_cookie ) |
#define | _Per_CPU_Release_all(isr_cookie) _ISR_Enable( isr_cookie ) |
#define | _Per_CPU_Get_snapshot() ( &_Per_CPU_Information[ _SMP_Get_current_processor() ].per_cpu ) |
#define | _Per_CPU_Get() _Per_CPU_Get_snapshot() |
#define | _Thread_Dispatch_disable_level _Per_CPU_Get()->thread_dispatch_disable_level |
#define | _Thread_Heir _Per_CPU_Get()->heir |
#define | _Thread_Executing _Per_CPU_Get()->executing |
#define | _ISR_Nest_level _Per_CPU_Get()->isr_nest_level |
#define | _CPU_Interrupt_stack_low _Per_CPU_Get()->interrupt_stack_low |
#define | _CPU_Interrupt_stack_high _Per_CPU_Get()->interrupt_stack_high |
#define | _Thread_Dispatch_necessary _Per_CPU_Get()->dispatch_necessary |
#define | _Thread_Time_of_last_context_switch _Per_CPU_Get()->time_of_last_context_switch |
In an SMP configuration, there will be multiple instances of this data structure – one per CPU – and the current CPU number will be used as the index.
◆ _Per_CPU_Acquire
| #define _Per_CPU_Acquire |
cpu | ) |
Value:do { \
(void) ( cpu ); \
} while ( 0 )
◆ _Per_CPU_ISR_disable_and_acquire
| #define _Per_CPU_ISR_disable_and_acquire |
cpu, |
isr_cookie |
Value:do { \
_ISR_Disable( isr_cookie ); \
(void) ( cpu ); \
} while ( 0 )
◆ _Per_CPU_Release
| #define _Per_CPU_Release |
cpu | ) |
Value:do { \
(void) ( cpu ); \
} while ( 0 )
◆ _Per_CPU_Release_and_ISR_enable
| #define _Per_CPU_Release_and_ISR_enable |
cpu, |
isr_cookie |
Value:do { \
(void) ( cpu ); \
_ISR_Enable( isr_cookie ); \
} while ( 0 )
◆ Per_CPU_Control
Per CPU Core Structure.
This structure is used to hold per core state information.
◆ _Thread_Get_executing()
Returns the thread control block of the executing thread.
This function can be called in any context. On SMP configurations interrupts are disabled to ensure that the processor index is used consistently.
- Returns
- The thread control block of the executing thread.
Referenced by _API_Mutex_Is_owner(), _MPCI_Receive_server(), _Objects_Id_to_name(), _RTEMS_Tasks_Invoke_task_variable_dtor(), _User_extensions_Iterate(), rtems_object_set_name(), rtems_rate_monotonic_create(), rtems_semaphore_create(), rtems_signal_catch(), rtems_stack_checker_is_blown(), rtems_task_get_note(), rtems_task_self(), and rtems_task_set_note().
◆ CPU_STRUCTURE_ALIGNMENT
Set of Per CPU Core Information.
This is an array of per CPU core information.
It is filled in by _CPU_Initialize and copied into the task's FP context area during _CPU_Context_Initialize.
