RTEMS 5.2
SC16IS752 device context. More...
#include <sc16is752.h>
Data Fields | |
| rtems_termios_device_context | base |
| int(* | write_reg )(sc16is752_context *ctx, uint8_t addr, const uint8_t *data, size_t len) |
| Writes a register. More... | |
| int(* | read_reg )(sc16is752_context *ctx, uint8_t addr, uint8_t *data, size_t len) |
| Reads a register. More... | |
| int(* | read_2_reg )(sc16is752_context *ctx, uint8_t addr_0, uint8_t addr_1, uint8_t data[2]) |
| Reads two registers. More... | |
| bool(* | first_open )(sc16is752_context *ctx) |
| First open. More... | |
| void(* | last_close )(sc16is752_context *ctx) |
| Last close. More... | |
| bool(* | install_irq )(sc16is752_context *ctx) |
| Shall install the interrupt handler. More... | |
| void(* | remove_irq )(sc16is752_context *ctx) |
| Shall remove the interrupt handler. More... | |
| sc16is752_mode | mode |
| Device mode. More... | |
| uint32_t | input_frequency |
| Input frequency in Hertz (dependent on crystal, see XTAL1 and XTAL2 pins). More... | |
| rtems_termios_tty * | tty |
| Corresponding Termios structure. More... | |
| uint8_t | ier |
| Shadow Interrupt Enable Register (IER). More... | |
| uint8_t | tx_in_progress |
| Characters placed into transmit FIFO. More... | |
| uint8_t | tx_fifo_free |
| Count of free characters in the transmit FIFO. More... | |
| uint8_t | lcr |
| Shadow Line Control Register (LCR). More... | |
| uint8_t | efcr |
| Shadow Extra Features Control Register (EFCR). More... | |
| uint8_t sc16is752_context::efcr |
Internal variable.
| bool(* sc16is752_context::first_open) (sc16is752_context *ctx) |
First open.
Internal handler.
| uint8_t sc16is752_context::ier |
Internal variable.
| uint32_t sc16is752_context::input_frequency |
Must be initialized by the user before the device creation.
| bool(* sc16is752_context::install_irq) (sc16is752_context *ctx) |
| void(* sc16is752_context::last_close) (sc16is752_context *ctx) |
Last close.
Internal handler.
| uint8_t sc16is752_context::lcr |
Internal variable.
| sc16is752_mode sc16is752_context::mode |
Device mode.
| int(* sc16is752_context::read_2_reg) (sc16is752_context *ctx, uint8_t addr_0, uint8_t addr_1, uint8_t data[2]) |
Internal handler.
| int(* sc16is752_context::read_reg) (sc16is752_context *ctx, uint8_t addr, uint8_t *data, size_t len) |
Reads a register.
Internal handler.
| void(* sc16is752_context::remove_irq) (sc16is752_context *ctx) |
| rtems_termios_tty* sc16is752_context::tty |
Internal variable.
| uint8_t sc16is752_context::tx_fifo_free |
Internal variable.
| uint8_t sc16is752_context::tx_in_progress |
Internal variable.
| int(* sc16is752_context::write_reg) (sc16is752_context *ctx, uint8_t addr, const uint8_t *data, size_t len) |
Writes a register.
Internal handler.
