RTEMS 5.2
Block device read-ahead control. More...
#include <diskdevs.h>
Data Fields | |
| rtems_chain_node | node |
| Chain node for the read-ahead request queue of the read-ahead task. | |
| rtems_blkdev_bnum | trigger |
| Block value to trigger the read-ahead request. More... | |
| rtems_blkdev_bnum | next |
| Start block for the next read-ahead request. More... | |
| rtems_blkdev_bnum rtems_blkdev_read_ahead::next |
In case the trigger value is out of range of valid blocks, this value my be arbitrary.
| rtems_blkdev_bnum rtems_blkdev_read_ahead::trigger |
A value of RTEMS_DISK_READ_AHEAD_NO_TRIGGER will disable further read-ahead requests since no valid block can have this value.
