RTEMS 5.2
#include <config.h>
Data Fields | |
| uint32_t | maximum_tasks |
| bool | notepads_enabled |
| uint32_t | maximum_timers |
| uint32_t | maximum_semaphores |
| uint32_t | maximum_message_queues |
| uint32_t | maximum_partitions |
| uint32_t | maximum_regions |
| uint32_t | maximum_ports |
| uint32_t | maximum_periods |
| uint32_t | maximum_barriers |
| uint32_t | number_of_initialization_tasks |
| const rtems_initialization_tasks_table * | User_initialization_tasks_table |
The following records define the Configuration Table. The information contained in this table is required in all RTEMS systems, whether single or multiprocessor. This table primarily defines the following:
| uint32_t rtems_api_configuration_table::maximum_barriers |
This field contains the maximum number of Classic API Barriers which are configured for this application.
| uint32_t rtems_api_configuration_table::maximum_message_queues |
This field contains the maximum number of Classic API Message Queues which are configured for this application.
| uint32_t rtems_api_configuration_table::maximum_partitions |
This field contains the maximum number of Classic API Partitions which are configured for this application.
| uint32_t rtems_api_configuration_table::maximum_periods |
This field contains the maximum number of Classic API Rate Monotonic Periods which are configured for this application.
| uint32_t rtems_api_configuration_table::maximum_ports |
This field contains the maximum number of Classic API Dual Ported Memory Areas which are configured for this application.
| uint32_t rtems_api_configuration_table::maximum_regions |
This field contains the maximum number of Classic API Regions which are configured for this application.
| uint32_t rtems_api_configuration_table::maximum_semaphores |
This field contains the maximum number of Classic API Semaphores which are configured for this application.
| uint32_t rtems_api_configuration_table::maximum_tasks |
This field contains the maximum number of Classic API Tasks which are configured for this application.
| uint32_t rtems_api_configuration_table::maximum_timers |
This field contains the maximum number of Classic API Timers which are configured for this application.
| bool rtems_api_configuration_table::notepads_enabled |
This field indicates whether Classic API notepads are enabled or disabled.
| uint32_t rtems_api_configuration_table::number_of_initialization_tasks |
This field contains the number of Classic API Initialization Tasks which are configured for this application.
| const rtems_initialization_tasks_table* rtems_api_configuration_table::User_initialization_tasks_table |
This field is the set of Classic API Initialization Tasks which are configured for this application.
