RTEMS 5.2
Inlined Routines Associated with Thread State Information. More...
| #define | STATES_READY 0x00000000 |
| #define | STATES_WAITING_FOR_MUTEX 0x00000001 |
| #define | STATES_WAITING_FOR_SEMAPHORE 0x00000002 |
| #define | STATES_WAITING_FOR_EVENT 0x00000004 |
| #define | STATES_WAITING_FOR_SYSTEM_EVENT 0x00000008 |
| #define | STATES_WAITING_FOR_MESSAGE 0x00000010 |
| #define | STATES_WAITING_FOR_CONDITION_VARIABLE 0x00000020 |
| #define | STATES_WAITING_FOR_FUTEX 0x00000040 |
| #define | STATES_WAITING_FOR_BSD_WAKEUP 0x00000080 |
| #define | STATES_WAITING_FOR_TIME 0x00000100 |
| This macro corresponds to a task which is waiting for a relative or absolute timeout. | |
| #define | STATES_WAITING_FOR_PERIOD 0x00000200 |
| #define | STATES_WAITING_FOR_SIGNAL 0x00000400 |
| #define | STATES_WAITING_FOR_BARRIER 0x00000800 |
| #define | STATES_WAITING_FOR_RWLOCK 0x00001000 |
| #define | STATES_WAITING_FOR_JOIN_AT_EXIT 0x00002000 |
| #define | STATES_WAITING_FOR_JOIN 0x00004000 |
| #define | STATES_SUSPENDED 0x00008000 |
| #define | STATES_WAITING_FOR_SEGMENT 0x00010000 |
| #define | STATES_LIFE_IS_CHANGING 0x00020000 |
| #define | STATES_DEBUGGER 0x08000000 |
| #define | STATES_INTERRUPTIBLE_BY_SIGNAL 0x10000000 |
| #define | STATES_WAITING_FOR_RPC_REPLY 0x20000000 |
| #define | STATES_ZOMBIE 0x40000000 |
| #define | STATES_DORMANT 0x80000000 |
| #define | STATES_LOCALLY_BLOCKED |
| #define | STATES_BLOCKED |
| #define | STATES_ALL_SET 0xffffffff |
| RTEMS_INLINE_ROUTINE States_Control | _States_Set (States_Control states_to_set, States_Control current_state) |
| Returns the result of setting the states to set to the given state. More... | |
| RTEMS_INLINE_ROUTINE States_Control | _States_Clear (States_Control states_to_clear, States_Control current_state) |
| Clears the states into the passed current state and returns the result. More... | |
| RTEMS_INLINE_ROUTINE bool | _States_Is_ready (States_Control the_states) |
| Checks if the state is ready. More... | |
| RTEMS_INLINE_ROUTINE bool | _States_Is_dormant (States_Control the_states) |
| Checks if DORMANT state is set. More... | |
| RTEMS_INLINE_ROUTINE bool | _States_Is_suspended (States_Control the_states) |
| Checks if SUSPENDED state is set. More... | |
| RTEMS_INLINE_ROUTINE bool | _States_Is_waiting_for_rpc_reply (States_Control the_states) |
| Checks if WAITING_FOR_TIME state is set. More... | |
| RTEMS_INLINE_ROUTINE bool | _States_Is_waiting_for_join_at_exit (States_Control the_states) |
| Checks if WAITING_FOR_JOIN_AT_EXIT state is set. More... | |
| RTEMS_INLINE_ROUTINE bool | _States_Is_interruptible_by_signal (States_Control the_states) |
| Checks if the state is set to be interruptible. More... | |
| RTEMS_INLINE_ROUTINE bool | _States_Is_locally_blocked (States_Control the_states) |
| Checks if the state is blocked waiting on a local resource. More... | |
This file contains the static inline implementation of the inlined routines associated with thread state information.
