RTEMS 5.2
#include "chip.h"#include <stdint.h>Go to the source code of this file.
| void | SSC_Configure (Ssc *ssc, uint32_t bitRate, uint32_t masterClock) |
| Configures a SSC peripheral.If the divided clock is not used, the master clock frequency can be set to 0. More... | |
| void | SSC_ConfigureTransmitter (Ssc *ssc, uint32_t tcmr, uint32_t tfmr) |
| Configures the transmitter of a SSC peripheral. More... | |
| void | SSC_ConfigureReceiver (Ssc *ssc, uint32_t rcmr, uint32_t rfmr) |
| Configures the receiver of a SSC peripheral. More... | |
| void | SSC_EnableTransmitter (Ssc *ssc) |
| Enables the transmitter of a SSC peripheral. More... | |
| void | SSC_DisableTransmitter (Ssc *ssc) |
| Disables the transmitter of a SSC peripheral. More... | |
| void | SSC_EnableReceiver (Ssc *ssc) |
| Enables the receiver of a SSC peripheral. More... | |
| void | SSC_DisableReceiver (Ssc *ssc) |
| Disables the receiver of a SSC peripheral. More... | |
| void | SSC_EnableInterrupts (Ssc *ssc, uint32_t sources) |
| Enables one or more interrupt sources of a SSC peripheral. More... | |
| void | SSC_DisableInterrupts (Ssc *ssc, uint32_t sources) |
| Disables one or more interrupt sources of a SSC peripheral. More... | |
| void | SSC_Write (Ssc *ssc, uint32_t frame) |
| Sends one data frame through a SSC peripheral. If another frame is currently being sent, this function waits for the previous transfer to complete. More... | |
| uint32_t | SSC_Read (Ssc *ssc) |
| Waits until one frame is received on a SSC peripheral, and returns it. More... | |
| uint8_t | SSC_IsRxReady (Ssc *ssc) |
| Return 1 if one frame is received, 0 otherwise. More... | |
Interface for Synchronous Serial (SSC) controller.
| void SSC_Configure | ( | Ssc * | ssc, |
| uint32_t | bitRate, | ||
| uint32_t | masterClock | ||
| ssc | Pointer to an SSC instance. |
| bitRate | bit rate. |
| masterClock | master clock. |
| void SSC_ConfigureReceiver | ( | Ssc * | ssc, |
| uint32_t | rcmr, | ||
| uint32_t | rfmr | ||
| rcmr | Receive Clock Mode Register value. |
| rfmr | Receive Frame Mode Register value. |
| void SSC_ConfigureTransmitter | ( | Ssc * | ssc, |
| uint32_t | tcmr, | ||
| uint32_t | tfmr | ||
| tcmr | Transmit Clock Mode Register value. |
| tfmr | Transmit Frame Mode Register value. |
| void SSC_DisableInterrupts | ( | Ssc * | ssc, |
| uint32_t | sources | ||
| sources | Bitwise OR of selected interrupt sources. |
| void SSC_DisableReceiver | ( | Ssc * | ssc | ) |
| void SSC_DisableTransmitter | ( | Ssc * | ssc | ) |
| void SSC_EnableInterrupts | ( | Ssc * | ssc, |
| void SSC_EnableReceiver | ( | Ssc * | ssc | ) |
| void SSC_EnableTransmitter | ( | Ssc * | ssc | ) |
| uint8_t SSC_IsRxReady | ( | Ssc * | ssc | ) |
| uint32_t SSC_Read | ( | Ssc * | ssc | ) |
| void SSC_Write | ( | Ssc * | ssc, |
| uint32_t | frame | ||
| frame | Data frame to send. |
