RTEMS 5.2
Protected Heap Handler API. More...
| RTEMS_INLINE_ROUTINE uintptr_t | _Protected_heap_Initialize (Heap_Control *heap, void *area_begin, uintptr_t area_size, uintptr_t page_size) |
| Initializes the protected heap. More... | |
| bool | _Protected_heap_Extend (Heap_Control *heap, void *area_begin, uintptr_t area_size) |
| Extends the protected heap. More... | |
| void * | _Protected_heap_Allocate_aligned_with_boundary (Heap_Control *heap, uintptr_t size, uintptr_t alignment, uintptr_t boundary) |
| Allocates an aligned memory area with boundary constraint for the protected heap. More... | |
| RTEMS_INLINE_ROUTINE void * | _Protected_heap_Allocate_aligned (Heap_Control *heap, uintptr_t size, uintptr_t alignment) |
| Allocates an aligned memory area. More... | |
| RTEMS_INLINE_ROUTINE void * | _Protected_heap_Allocate (Heap_Control *heap, uintptr_t size) |
| Allocates a memory area. More... | |
| bool | _Protected_heap_Get_block_size (Heap_Control *heap, void *addr, uintptr_t *size) |
| Returns the size of the allocatable memory area. More... | |
| bool | _Protected_heap_Resize_block (Heap_Control *heap, void *addr, uintptr_t size) |
| Resizes the block of the allocated memory area. More... | |
| bool | _Protected_heap_Free (Heap_Control *heap, void *addr) |
| Frees the allocated memory area. More... | |
| bool | _Protected_heap_Walk (Heap_Control *heap, int source, bool dump) |
| Verifies the integrity of the heap. More... | |
| void | _Protected_heap_Iterate (Heap_Control *heap, Heap_Block_visitor visitor, void *visitor_arg) |
| Iterates over all blocks of the heap. More... | |
| bool | _Protected_heap_Get_information (Heap_Control *heap, Heap_Information_block *info) |
| Returns information about used and free blocks for the heap. More... | |
| bool | _Protected_heap_Get_free_information (Heap_Control *heap, Heap_Information *info) |
| Returns information about free blocks for the heap. More... | |
| uintptr_t | _Protected_heap_Get_size (Heap_Control *heap) |
| Returns the size of the allocatable area in bytes. More... | |
