int | assert_sw_irw (uint32_t irqnum) |
int | negate_sw_irw (uint32_t irqnum) |
◆ Cause_tm27_intr
| #define Cause_tm27_intr |
void | ) |
Value: do { \
assert_sw_irq(0); \
} while(0)
◆ Clear_tm27_intr
| #define Clear_tm27_intr |
void | ) |
Value: do { \
negate_sw_irq(0); \
} while(0)
◆ Install_tm27_vector
| #define Install_tm27_vector |
handler | ) |
Value:
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
rtems_status_code rtems_interrupt_handler_install(rtems_vector_number vector, const char *info, rtems_option options, rtems_interrupt_handler handler, void *arg)
Installs the interrupt handler routine handler for the interrupt vector with number vector.
Definition: irq.c:127
void(* rtems_interrupt_handler)(void *)
Interrupt handler routine type.
Definition: irq-extension.h:79
◆ Lower_tm27_intr
| #define Lower_tm27_intr |
void | ) |
Value: do { \
continue;\
} while(0)
