Motorola M68K CPU Dependent Source.
More...
#define | CPU_NAME "Motorola MC68xxx" |
#define | M68K_CPU_STACK_MINIMUM_SIZE 4096 |
#define | M68K_CPU_PRIORITY_MAXIMUM 255 |
#define | M68K_COLDFIRE_ARCH 0 |
| #define | m68k_disable_interrupts(_level) |
#define | m68k_enable_interrupts(_level) __asm__ volatile ( "move.w %0,%%sr " : : "d" (_level) : "cc"); |
| #define | m68k_flash_interrupts(_level) |
| #define | m68k_get_interrupt_level(_level) |
| #define | m68k_set_interrupt_level(_newlevel) |
#define | m68k_get_vbr(_vbr) _vbr = (void *)_VBR |
#define | m68k_set_vbr(_vbr) |
#define | m68k_set_cacr(_cacr) __asm__ volatile ("movec %0,%%cacr" : : "d" (_cacr)) |
#define | m68k_set_acr0(_acr0) __asm__ volatile ("movec %0,%%acr0" : : "d" (_acr0)) |
#define | m68k_set_acr1(_acr1) __asm__ volatile ("movec %0,%%acr1" : : "d" (_acr1)) |
#define | CPU_swap_u32(value) m68k_swap_u32( value ) |
#define | CPU_swap_u16(value) m68k_swap_u16( value ) |
◆ m68k_disable_interrupts
| #define m68k_disable_interrupts |
_level | ) |
Value: __asm__ volatile (
"move.w %%sr,%0\n\t" \
"or.w #0x0700,%%sr" \
: "=d" (_level) \
: : "cc" )
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
◆ m68k_flash_interrupts
| #define m68k_flash_interrupts |
_level | ) |
"move.w %0,%%sr\n\t" \
: : "d" (_level) \
: "cc" )
◆ m68k_get_interrupt_level
| #define m68k_get_interrupt_level |
_level | ) |
Value: do { \
uint32_t _tmpsr; \
__asm__ volatile( "move.w %%sr,%0" : "=d" (_tmpsr)); \
_level = (_tmpsr & 0x0700) >> 8; \
} while (0)
◆ m68k_set_interrupt_level
| #define m68k_set_interrupt_level |
_newlevel | ) |
Value: do { \
uint32_t _tmpsr; \
_tmpsr = (_tmpsr & 0xf8ff) | ((_newlevel) << 8); \
__asm__ volatile( "move.w %0,%%sr" : : "d" (_tmpsr)); \
} while (0)
