| file | __assert.c |
| | Evaluate Assertion.
| file | __getpid.c |
| | Get Process Id.
| file | __gettod.c |
| | Get the Date and Time.
| file | __times.c |
| | Get Process Times.
| file | _calloc_r.c |
| | Allocate Space for Array in Memory.
| file | _free_r.c |
| | Allocate and Free Dynamic Memory.
| file | _realloc_r.c |
| | _realloc_r Implementation
| file | _rename_r.c |
| | Rename a File.
| file | access.c |
| | access() - POSIX 1003.1b 5.6.3 - File Accessibility
| file | calloc.c |
| file | chmod.c |
| | Change File Modes.
| file | chown.c |
| | Change Owner and Group of a File.
| file | chroot.c |
| | Change Root Directory.
| file | close.c |
| | POSIX 1003.1b 6.3.1 - Close a File.
| file | ctermid.c |
| | Generate Terminal Pathname.
| file | dup.c |
| | POSIX 1003.1b 6.2.1 Duplicate an Open File Descriptor.
| file | dup2.c |
| file | fchdir.c |
| | Change Directory.
| file | fchmod.c |
| | Change File Modes.
| file | fchown.c |
| file | fcntl.c |
| | POSIX 1003.1b 6.5.2 - File Control.
| file | fdatasync.c |
| | POSIX 1003.1b 6.6.2 - Synchronize the Data of a File.
| file | fpathconf.c |
| | Configurable Pathname Varables.
| file | free.c |
| | calloc()
| file | fsync.c |
| | Synchronize the State of a File.
| file | ftruncate.c |
| | Truncate a File to the Specified Length.
| file | funlockfile.c |
| | Unlock File for Stdio.
| file | getchark.c |
| | Get Character from Stdin.
| file | getdents.c |
| | Get Directory Entries.
| file | getegid.c |
| | Get Real User, Effective User, Ral Group, and Effective Group IDs.
| file | geteuid.c |
| file | getgid.c |
| file | getgrent.c |
| | User Database Access Routines.
| file | getgrnam.c |
| file | getgroups.c |
| | Get Supplementary IDs.
| file | getlogin.c |
| | Get User Name.
| file | getpagesize.c |
| | Get System Page Size.
| file | getpid.c |
| | Process and Parent Process IDs.
| file | getppid.c |
| | Get Process and Parent Process IDs.
| file | getpwent.c |
| file | getuid.c |
| file | ioctl.c |
| | ioctl() system call
| file | isatty_r.c |
| | Test for a Terminal Device.
| file | issetugid.c |
| | Dummy Version of BSD Routine.
| file | kill_noposix.c |
| | Kill No POSIX.
| file | link.c |
| | Create a new link.
| file | lstat.c |
| | Get File Status.
| file | malloc.c |
| | RTEMS Malloc Family Implementation.
| file | malloc_deferred.c |
| | Malloc Deferred Support.
| file | malloc_walk.c |
| | Malloc Walk.
| file | mallocfreespace.c |
| | RTEMS Malloc Get Free Information.
| file | mallocgetheapptr.c |
| | RTEMS Malloc Get Heap Pointer.
| file | mallocinfo.c |
| | RTEMS Malloc Get Status Information.
| file | mallocsetheapptr.c |
| | RTEMS Malloc Set Heap Pointer.
| file | mkdir.c |
| | Make a Directory.
| file | mkfifo.c |
| | Make a FIFO Special File.
| file | mknod.c |
| | Create a Special or Ordinary File.
| file | newlibc_reent.c |
| | Newlib Support.
| file | open.c |
| | Open a File.
| file | pathconf.c |
| file | posix_memalign.c |
| file | print_fprintf.c |
| | RTEMS Print Support.
| file | print_printf.c |
| file | printf_plugin.c |
| | RTEMS Plugin Printf.
| file | printk.c |
| | Kernel Printf Function.
| file | printk_plugin.c |
| | Plugin Printk.
| file | putk.c |
| | Write Character to Stream.
| file | pwdgrp.c |
| file | read.c |
| | Read From a File.
| file | readlink.c |
| | Read Value of a Symbolic Link.
| file | readv.c |
| | Read a Vector.
| file | realloc.c |
| | Reallocate Memory Block.
| file | rmdir.c |
| | Remove a Directory.
| file | rtems_heap_extend.c |
| | rtems_heap_extend() implementation.
| file | rtems_putc.c |
| | RTEMS Output a Character.
| file | setegid.c |
| file | seteuid.c |
| | Set Effective User Id.
| file | setpgid.c |
| | Set Process Group ID for Job Control.
| file | setsid.c |
| | Create Session and Set Process Group ID.
| file | stat.c |
| | Get File Status.
| file | symlink.c |
| | Make a Symbolic Link to a File.
| file | sync.c |
| | This source file contains the implementation of sync().
| file | tcgetpgrp.c |
| | Get Foreground Process Group ID.
| file | tcsetattr.c |
| | Get and Set State.
| file | tcsetpgrp.c |
| | Set Foreground Process Group ID.
| file | truncate.c |
| file | umask.c |
| | Set File Creation Mask.
| file | unlink.c |
| | Remove an Existing Link.
| file | unmount.c |
| | Unmount a File System.
| file | utime.c |
| | Set File Access and Modification Times.
| file | utimes.c |
| | Change File Last Access and Modification Times.
| file | vprintk.c |
| | Print Formatted Output.
| file | write.c |
| | Write to a File.
| file | write_r.c |
| | POSIX 1003.1b 6.4.2 - Write to a File.
RTEMS Specific Support for the Standard C Library.
