RTEMS 5.2
Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
Event Recording
Low-level event recording support. More...
struct  rtems_record_client_per_cpu
struct  rtems_record_client_context
struct  rtems_record_item_32
 The 32-bit format record item. More...
struct  rtems_record_dump_base64_zlib_context
 The context for record dumps with zlib compression and base64 encoding. More...
#define rtems_record_caller()   _Record_Caller( RTEMS_RETURN_ADDRESS() )
 Generates an RTEMS_RECORD_CALLER and an RTEMS_RECORD_LINE event. More...
#define rtems_record_caller_3(event, data)    _Record_Caller_3( RTEMS_RETURN_ADDRESS(), event, data )
 Generates an RTEMS_RECORD_CALLER, an RTEMS_RECORD_LINE event, and an extra event. More...
#define rtems_record_caller_4(event_0, data_0, event_1, data_1)
 Generates an RTEMS_RECORD_CALLER, an RTEMS_RECORD_LINE event, and two extra events. More...
#define rtems_record_caller_arg(data)    _Record_Caller_arg( RTEMS_RETURN_ADDRESS(), data )
 Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and one argument event. More...
#define rtems_record_caller_arg_2(data_0, data_1)
 Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and two argument events. More...
#define rtems_record_caller_arg_3(data_0, data_1, data_2)
 Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and three argument events. More...
#define rtems_record_caller_arg_4(data_0, data_1, data_2, data_3)
 Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and four argument events. More...
#define rtems_record_caller_arg_5(data_0, data_1, data_2, data_3, data_4)
 Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and five argument events. More...
#define rtems_record_caller_arg_6(data_0, data_1, data_2, data_3, data_4, data_5)
 Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and six argument events. More...
#define rtems_record_caller_arg_7(data_0, data_1, data_2, data_3, data_4, data_5, data_6)
 Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and seven argument events. More...
#define rtems_record_caller_arg_8(data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7)
 Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and eight argument events. More...
#define rtems_record_caller_arg_9(data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7, data_8)
 Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and nine argument events. More...
#define rtems_record_caller_arg_10(data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7, data_8, data_9)
 Generates an RTEMS_RECORD_CALLER event, an RTEMS_RECORD_LINE event, and ten argument events. More...
#define rtems_record_entry(event)    rtems_record_produce( event, (rtems_record_data) RTEMS_RETURN_ADDRESS() )
 Generates the specified entry event. More...
#define rtems_record_entry_1(event, data)
 Generates the specified entry event and an argument event. More...
#define rtems_record_entry_2(event, data_0, data_1)    _Record_Entry_2( RTEMS_RETURN_ADDRESS(), event, data_0, data_1 )
 Generates the specified entry event and two argument events. More...
#define rtems_record_entry_3(event, data_0, data_1, data_2)
 Generates the specified entry event and three argument events. More...
#define rtems_record_entry_4(event, data_0, data_1, data_2, data_3)
 Generates the specified entry event and four argument events. More...
#define rtems_record_entry_5(event, data_0, data_1, data_2, data_3, data_4)
 Generates the specified entry event and five argument events. More...
#define rtems_record_entry_6(event, data_0, data_1, data_2, data_3, data_4, data_5)
 Generates the specified entry event and six argument events. More...
#define rtems_record_entry_7(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6)
 Generates the specified entry event and seven argument events. More...
#define rtems_record_entry_8(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7)
 Generates the specified entry event and eight argument events. More...
#define rtems_record_entry_9(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7, data_8)
 Generates the specified entry event and nine argument events. More...
#define rtems_record_entry_10(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7, data_8, data_9)
 Generates the specified entry event and ten argument events. More...
#define rtems_record_exit(event)    rtems_record_produce( event, (rtems_record_data) RTEMS_RETURN_ADDRESS() )
 Generates the specified exit event. More...
#define rtems_record_exit_1(event, data)
 Generates the specified exit event and a return event. More...
#define rtems_record_exit_2(event, data_0, data_1)    _Record_Entry_2( RTEMS_RETURN_ADDRESS(), event, data_0, data_1 )
 Generates the specified exit event and two argument events. More...
#define rtems_record_exit_3(event, data_0, data_1, data_2)
 Generates the specified exit event and three argument events. More...
#define rtems_record_exit_4(event, data_0, data_1, data_2, data_3)
 Generates the specified exit event and four argument events. More...
#define rtems_record_exit_5(event, data_0, data_1, data_2, data_3, data_4)
 Generates the specified exit event and five argument events. More...
#define rtems_record_exit_6(event, data_0, data_1, data_2, data_3, data_4, data_5)
 Generates the specified exit event and six argument events. More...
#define rtems_record_exit_7(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6)
 Generates the specified exit event and seven argument events. More...
#define rtems_record_exit_8(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7)
 Generates the specified exit event and eight argument events. More...
#define rtems_record_exit_9(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7, data_8)
 Generates the specified exit event and nine argument events. More...
#define rtems_record_exit_10(event, data_0, data_1, data_2, data_3, data_4, data_5, data_6, data_7, data_8, data_9)
 Generates the specified exit event and ten argument events. More...
#define RTEMS_RECORD_CLIENT_MAXIMUM_CPU_COUNT   32
#define RTEMS_RECORD_THE_VERSION   9
 The record version. More...
#define RTEMS_RECORD_FORMAT_LE_32   0x11111111
 The items are in 32-bit little-endian format.
#define RTEMS_RECORD_FORMAT_LE_64   0x22222222
 The items are in 64-bit little-endian format.
#define RTEMS_RECORD_FORMAT_BE_32   0x33333333
 The items are in 32-bit big-endian format.
#define RTEMS_RECORD_FORMAT_BE_64   0x44444444
 The items are in 64-bit big-endian format.
#define RTEMS_RECORD_MAGIC   0x82e14ec1
 Magic number to identify a record item stream. More...
#define RTEMS_RECORD_LAST   RTEMS_RECORD_USER_511
#define RTEMS_RECORD_USER(index)   ( RTEMS_RECORD_USER_0 + ( index ) )
#define RTEMS_RECORD_EVENT_BITS   10
 Bits in the record item event member reserved for the actual event.
#define RTEMS_RECORD_TIME_BITS   22
 Bits in the record item event member reserved for the time of the event.
#define RTEMS_RECORD_TIME_EVENT(time, event)    ( ( ( time ) << RTEMS_RECORD_EVENT_BITS ) | ( event ) )
 Builds a time event for the specified time stamp and event. More...
#define RTEMS_RECORD_GET_TIME(time_event)    ( ( time_event ) >> RTEMS_RECORD_EVENT_BITS )
 Gets the time of a time event.
#define RTEMS_RECORD_GET_EVENT(time_event)    ( ( time_event ) & ( ( 1U << RTEMS_RECORD_EVENT_BITS ) - 1U ) )
 Gets the event of a time event.
typedef void(* rtems_record_drain_visitor) (const rtems_record_item *items, size_t count, void *arg)
typedef rtems_record_client_status(* rtems_record_client_handler) (uint64_t bt, uint32_t cpu, rtems_record_event event, uint64_t data, void *arg)
typedef struct rtems_record_client_context rtems_record_client_context
typedef unsigned long rtems_record_data
 The record data integer type. More...
typedef void(* rtems_record_dump_chunk) (void *arg, const void *data, size_t length)
 Handler for record dumps to output a chunk of data. More...
enum  rtems_record_client_status {
  RTEMS_RECORD_CLIENT_SUCCESS , RTEMS_RECORD_CLIENT_ERROR_INVALID_MAGIC , RTEMS_RECORD_CLIENT_ERROR_UNKNOWN_FORMAT , RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_VERSION ,
  RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_CPU , RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_CPU_MAX , RTEMS_RECORD_CLIENT_ERROR_DOUBLE_CPU_MAX , RTEMS_RECORD_CLIENT_ERROR_DOUBLE_PER_CPU_COUNT ,
  RTEMS_RECORD_CLIENT_ERROR_NO_CPU_MAX , RTEMS_RECORD_CLIENT_ERROR_NO_MEMORY , RTEMS_RECORD_CLIENT_ERROR_PER_CPU_ITEMS_OVERFLOW
enum  rtems_record_event {
  RTEMS_RECORD_EMPTY , RTEMS_RECORD_VERSION , RTEMS_RECORD_ACCEPT_ENTRY , RTEMS_RECORD_ACCEPT_EXIT ,
  RTEMS_RECORD_ADDRESS , RTEMS_RECORD_ALIGNED_ALLOC_ENTRY , RTEMS_RECORD_ALIGNED_ALLOC_EXIT , RTEMS_RECORD_ARCH ,
  RTEMS_RECORD_ARG_0 , RTEMS_RECORD_ARG_1 , RTEMS_RECORD_ARG_2 , RTEMS_RECORD_ARG_3 ,
  RTEMS_RECORD_ARG_4 , RTEMS_RECORD_ARG_5 , RTEMS_RECORD_ARG_6 , RTEMS_RECORD_ARG_7 ,
  RTEMS_RECORD_ARG_8 , RTEMS_RECORD_ARG_9 , RTEMS_RECORD_BIND_ENTRY , RTEMS_RECORD_BIND_EXIT ,
  RTEMS_RECORD_BSP , RTEMS_RECORD_BUFFER , RTEMS_RECORD_CALLER , RTEMS_RECORD_CALLOC_ENTRY ,
  RTEMS_RECORD_CALLOC_EXIT , RTEMS_RECORD_CHOWN_ENTRY , RTEMS_RECORD_CHOWN_EXIT , RTEMS_RECORD_CLOSE_ENTRY ,
  RTEMS_RECORD_CLOSE_EXIT , RTEMS_RECORD_CONNECT_ENTRY , RTEMS_RECORD_CONNECT_EXIT , RTEMS_RECORD_ETHER_INPUT ,
  RTEMS_RECORD_ETHER_OUTPUT , RTEMS_RECORD_ERRNO , RTEMS_RECORD_FATAL_CODE , RTEMS_RECORD_FATAL_SOURCE ,
  RTEMS_RECORD_FCHMOD_ENTRY , RTEMS_RECORD_FCHMOD_EXIT , RTEMS_RECORD_FCNTL_ENTRY , RTEMS_RECORD_FCNTL_EXIT ,
  RTEMS_RECORD_FDATASYNC_ENTRY , RTEMS_RECORD_FDATASYNC_EXIT , RTEMS_RECORD_FREE_ENTRY , RTEMS_RECORD_FREE_EXIT ,
  RTEMS_RECORD_FREQUENCY , RTEMS_RECORD_FSTAT_ENTRY , RTEMS_RECORD_FSTAT_EXIT , RTEMS_RECORD_FSYNC_ENTRY ,
  RTEMS_RECORD_FSYNC_EXIT , RTEMS_RECORD_FTRUNCATE_ENTRY , RTEMS_RECORD_FTRUNCATE_EXIT , RTEMS_RECORD_FUNCTION_ENTRY ,
  RTEMS_RECORD_FUNCTION_EXIT , RTEMS_RECORD_GETSOCKOPT_ENTRY , RTEMS_RECORD_GETSOCKOPT_EXIT , RTEMS_RECORD_HEAP_ALLOC ,
  RTEMS_RECORD_HEAP_FREE , RTEMS_RECORD_HEAP_SIZE , RTEMS_RECORD_HEAP_USAGE , RTEMS_RECORD_INTERRUPT_ENTRY ,
  RTEMS_RECORD_INTERRUPT_EXIT , RTEMS_RECORD_INTERRUPT_INSTALL , RTEMS_RECORD_INTERRUPT_REMOVE , RTEMS_RECORD_INTERRUPT_SERVER_ENTRY ,
  RTEMS_RECORD_INTERRUPT_SERVER_EXIT , RTEMS_RECORD_INTERRUPT_SERVER_INSTALL , RTEMS_RECORD_INTERRUPT_SERVER_MOVE , RTEMS_RECORD_INTERRUPT_SERVER_REMOVE ,
  RTEMS_RECORD_INTERRUPT_SERVER_TRIGGER , RTEMS_RECORD_IOCTL_ENTRY , RTEMS_RECORD_IOCTL_EXIT , RTEMS_RECORD_IP6_INPUT ,
  RTEMS_RECORD_IP6_OUTPUT , RTEMS_RECORD_IP_INPUT , RTEMS_RECORD_IP_OUTPUT , RTEMS_RECORD_ISR_DISABLE ,
  RTEMS_RECORD_ISR_ENABLE , RTEMS_RECORD_ISR_LOCK_ACQUIRE_ENTRY , RTEMS_RECORD_ISR_LOCK_ACQUIRE_EXIT , RTEMS_RECORD_ISR_LOCK_ADDRESS ,
  RTEMS_RECORD_ISR_LOCK_DESTROY , RTEMS_RECORD_ISR_LOCK_INITIALIZE , RTEMS_RECORD_ISR_LOCK_NAME , RTEMS_RECORD_ISR_LOCK_RELEASE ,
  RTEMS_RECORD_KEVENT_ENTRY , RTEMS_RECORD_KEVENT_EXIT , RTEMS_RECORD_KQUEUE_ENTRY , RTEMS_RECORD_KQUEUE_EXIT ,
  RTEMS_RECORD_LENGTH , RTEMS_RECORD_LINE , RTEMS_RECORD_LINK_ENTRY , RTEMS_RECORD_LINK_EXIT ,
  RTEMS_RECORD_LISTEN_ENTRY , RTEMS_RECORD_LISTEN_EXIT , RTEMS_RECORD_LSEEK_ENTRY , RTEMS_RECORD_LSEEK_EXIT ,
  RTEMS_RECORD_MALLOC_ENTRY , RTEMS_RECORD_MALLOC_EXIT , RTEMS_RECORD_MEMORY , RTEMS_RECORD_MKNOD_ENTRY ,
  RTEMS_RECORD_MKNOD_EXIT , RTEMS_RECORD_MMAP_ENTRY , RTEMS_RECORD_MMAP_EXIT , RTEMS_RECORD_MOUNT_ENTRY ,
  RTEMS_RECORD_MOUNT_EXIT , RTEMS_RECORD_MULTILIB , RTEMS_RECORD_OPEN_ENTRY , RTEMS_RECORD_OPEN_EXIT ,
  RTEMS_RECORD_PAGE_ALLOC , RTEMS_RECORD_PAGE_FREE , RTEMS_RECORD_PER_CPU_COUNT , RTEMS_RECORD_PER_CPU_HEAD ,
  RTEMS_RECORD_PER_CPU_OVERFLOW , RTEMS_RECORD_PER_CPU_TAIL , RTEMS_RECORD_POLL_ENTRY , RTEMS_RECORD_POLL_EXIT ,
  RTEMS_RECORD_POSIX_MEMALIGN_ENTRY , RTEMS_RECORD_POSIX_MEMALIGN_EXIT , RTEMS_RECORD_PROCESSOR , RTEMS_RECORD_PROCESSOR_MAXIMUM ,
  RTEMS_RECORD_READ_ENTRY , RTEMS_RECORD_READ_EXIT , RTEMS_RECORD_READLINK_ENTRY , RTEMS_RECORD_READLINK_EXIT ,
  RTEMS_RECORD_READV_ENTRY , RTEMS_RECORD_READV_EXIT , RTEMS_RECORD_REALLOC_ENTRY , RTEMS_RECORD_REALLOC_EXIT ,
  RTEMS_RECORD_RECV_ENTRY , RTEMS_RECORD_RECV_EXIT , RTEMS_RECORD_RECVFROM_ENTRY , RTEMS_RECORD_RECVFROM_EXIT ,
  RTEMS_RECORD_RECVMSG_ENTRY , RTEMS_RECORD_RECVMSG_EXIT , RTEMS_RECORD_REGISTERS , RTEMS_RECORD_RENAME_ENTRY ,
  RTEMS_RECORD_RENAME_EXIT , RTEMS_RECORD_RETURN_0 , RTEMS_RECORD_RETURN_1 , RTEMS_RECORD_RETURN_2 ,
  RTEMS_RECORD_RETURN_3 , RTEMS_RECORD_RETURN_4 , RTEMS_RECORD_RETURN_5 , RTEMS_RECORD_RETURN_6 ,
  RTEMS_RECORD_RETURN_7 , RTEMS_RECORD_RETURN_8 , RTEMS_RECORD_RETURN_9 , RTEMS_RECORD_RTEMS_BARRIER_CREATE ,
  RTEMS_RECORD_RTEMS_BARRIER_DELETE , RTEMS_RECORD_RTEMS_BARRIER_RELEASE , RTEMS_RECORD_RTEMS_BARRIER_WAIT , RTEMS_RECORD_RTEMS_CALLOC_ENTRY ,
  RTEMS_RECORD_RTEMS_CALLOC_EXIT , RTEMS_RECORD_RTEMS_EVENT_RECEIVE , RTEMS_RECORD_RTEMS_EVENT_SEND , RTEMS_RECORD_RTEMS_EVENT_SYSTEM_RECEIVE ,
  RTEMS_RECORD_RTEMS_EVENT_SYSTEM_SEND , RTEMS_RECORD_RTEMS_MALLOC_ENTRY , RTEMS_RECORD_RTEMS_MALLOC_EXIT , RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_BROADCAST ,
  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_CREATE , RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_DELETE , RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_FLUSH , RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_RECEIVE ,
  RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_SEND , RTEMS_RECORD_RTEMS_MESSAGE_QUEUE_URGENT , RTEMS_RECORD_RTEMS_PARTITION_CREATE , RTEMS_RECORD_RTEMS_PARTITION_DELETE ,
  RTEMS_RECORD_RTEMS_PARTITION_GET_BUFFER , RTEMS_RECORD_RTEMS_PARTITION_RETURN_BUFFER , RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CANCEL , RTEMS_RECORD_RTEMS_RATE_MONOTONIC_CREATE ,
  RTEMS_RECORD_RTEMS_RATE_MONOTONIC_DELETE , RTEMS_RECORD_RTEMS_RATE_MONOTONIC_PERIOD , RTEMS_RECORD_RTEMS_SEMAPHORE_CREATE , RTEMS_RECORD_RTEMS_SEMAPHORE_DELETE ,
  RTEMS_RECORD_RTEMS_SEMAPHORE_FLUSH , RTEMS_RECORD_RTEMS_SEMAPHORE_OBTAIN , RTEMS_RECORD_RTEMS_SEMAPHORE_RELEASE , RTEMS_RECORD_RTEMS_TIMER_CANCEL ,
  RTEMS_RECORD_RTEMS_TIMER_CREATE , RTEMS_RECORD_RTEMS_TIMER_DELETE , RTEMS_RECORD_RTEMS_TIMER_FIRE_AFTER , RTEMS_RECORD_RTEMS_TIMER_FIRE_WHEN ,
  RTEMS_RECORD_RTEMS_TIMER_RESET , RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_AFTER , RTEMS_RECORD_RTEMS_TIMER_SERVER_FIRE_WHEN , RTEMS_RECORD_SBWAIT_ENTRY ,
  RTEMS_RECORD_SBWAIT_EXIT , RTEMS_RECORD_SBWAKEUP_ENTRY , RTEMS_RECORD_SBWAKEUP_EXIT , RTEMS_RECORD_SCHEDULER_ADD_PROCESSOR ,
  RTEMS_RECORD_SCHEDULER_ASK_FOR_HELP , RTEMS_RECORD_SCHEDULER_BLOCK , RTEMS_RECORD_SCHEDULER_CANCEL_JOB , RTEMS_RECORD_SCHEDULER_ID ,
  RTEMS_RECORD_SCHEDULER_MAP_PRIORITY , RTEMS_RECORD_SCHEDULER_NAME , RTEMS_RECORD_SCHEDULER_PIN , RTEMS_RECORD_SCHEDULER_RECONSIDER_HELP_REQUEST ,
  RTEMS_RECORD_SCHEDULER_RELEASE_JOB , RTEMS_RECORD_SCHEDULER_REMOVE_PROCESSOR , RTEMS_RECORD_SCHEDULER_SCHEDULE , RTEMS_RECORD_SCHEDULER_SET_AFFINITY ,
  RTEMS_RECORD_SCHEDULER_TICK , RTEMS_RECORD_SCHEDULER_UNBLOCK , RTEMS_RECORD_SCHEDULER_UNMAP_PRIORITY , RTEMS_RECORD_SCHEDULER_UNPIN ,
  RTEMS_RECORD_SCHEDULER_UPDATE_PRIORITY , RTEMS_RECORD_SCHEDULER_WITHDRAW_NODE , RTEMS_RECORD_SCHEDULER_YIELD , RTEMS_RECORD_SELECT_ENTRY ,
  RTEMS_RECORD_SELECT_EXIT , RTEMS_RECORD_SEND_ENTRY , RTEMS_RECORD_SEND_EXIT , RTEMS_RECORD_SENDMSG_ENTRY ,
  RTEMS_RECORD_SENDMSG_EXIT , RTEMS_RECORD_SENDTO_ENTRY , RTEMS_RECORD_SENDTO_EXIT , RTEMS_RECORD_SETSOCKOPT_ENTRY ,
  RTEMS_RECORD_SETSOCKOPT_EXIT , RTEMS_RECORD_SHUTDOWN_ENTRY , RTEMS_RECORD_SHUTDOWN_EXIT , RTEMS_RECORD_SOABORT_ENTRY ,
  RTEMS_RECORD_SOABORT_EXIT , RTEMS_RECORD_SOACCEPT_ENTRY , RTEMS_RECORD_SOACCEPT_EXIT , RTEMS_RECORD_SOALLOC_ENTRY ,
  RTEMS_RECORD_SOALLOC_EXIT , RTEMS_RECORD_SOBINDAT_ENTRY , RTEMS_RECORD_SOBINDAT_EXIT , RTEMS_RECORD_SOBIND_ENTRY ,
  RTEMS_RECORD_SOBIND_EXIT , RTEMS_RECORD_SOCKET_ENTRY , RTEMS_RECORD_SOCKET_EXIT , RTEMS_RECORD_SOCLOSE_ENTRY ,
  RTEMS_RECORD_SOCLOSE_EXIT , RTEMS_RECORD_SOCONNECT2_ENTRY , RTEMS_RECORD_SOCONNECT2_EXIT , RTEMS_RECORD_SOCONNECTAT_ENTRY ,
  RTEMS_RECORD_SOCONNECTAT_EXIT , RTEMS_RECORD_SOCREATE_ENTRY , RTEMS_RECORD_SOCREATE_EXIT , RTEMS_RECORD_SODEALLOC_ENTRY ,
  RTEMS_RECORD_SODEALLOC_EXIT , RTEMS_RECORD_SODISCONNECT_ENTRY , RTEMS_RECORD_SODISCONNECT_EXIT , RTEMS_RECORD_SOFREE_ENTRY ,
  RTEMS_RECORD_SOFREE_EXIT , RTEMS_RECORD_SOLISTEN_ENTRY , RTEMS_RECORD_SOLISTEN_EXIT , RTEMS_RECORD_SONEWCONN_ENTRY ,
  RTEMS_RECORD_SONEWCONN_EXIT , RTEMS_RECORD_SORECEIVE_ENTRY , RTEMS_RECORD_SORECEIVE_EXIT , RTEMS_RECORD_SORFLUSH_ENTRY ,
  RTEMS_RECORD_SORFLUSH_EXIT , RTEMS_RECORD_SOSEND_ENTRY , RTEMS_RECORD_SOSEND_EXIT , RTEMS_RECORD_SOSHUTDOWN_ENTRY ,
  RTEMS_RECORD_SOSHUTDOWN_EXIT , RTEMS_RECORD_STATVFS_ENTRY , RTEMS_RECORD_STATVFS_EXIT , RTEMS_RECORD_SYMLINK_ENTRY ,
  RTEMS_RECORD_SYMLINK_EXIT , RTEMS_RECORD_TCP_CLOSE , RTEMS_RECORD_TCP_INPUT , RTEMS_RECORD_TCP_OUTPUT ,
  RTEMS_RECORD_THREAD_BEGIN , RTEMS_RECORD_THREAD_CONTINUE_ENTRY , RTEMS_RECORD_THREAD_CONTINUE_EXIT , RTEMS_RECORD_THREAD_CREATE ,
  RTEMS_RECORD_THREAD_DELETE , RTEMS_RECORD_THREAD_DISPATCH_DISABLE , RTEMS_RECORD_THREAD_DISPATCH_ENABLE , RTEMS_RECORD_THREAD_EXIT ,
  RTEMS_RECORD_THREAD_EXITTED , RTEMS_RECORD_THREAD_ID , RTEMS_RECORD_THREAD_NAME , RTEMS_RECORD_THREAD_PRIO_CURRENT_HIGH ,
  RTEMS_RECORD_THREAD_PRIO_CURRENT_LOW , RTEMS_RECORD_THREAD_PRIO_REAL_HIGH , RTEMS_RECORD_THREAD_PRIO_REAL_LOW , RTEMS_RECORD_THREAD_QUEUE_ADDRESS ,
  RTEMS_RECORD_THREAD_QUEUE_DESTROY , RTEMS_RECORD_THREAD_QUEUE_ENQUEUE , RTEMS_RECORD_THREAD_QUEUE_ENQUEUE_STICKY , RTEMS_RECORD_THREAD_QUEUE_EXTRACT ,
  RTEMS_RECORD_THREAD_QUEUE_ID , RTEMS_RECORD_THREAD_QUEUE_INITIALIZE , RTEMS_RECORD_THREAD_QUEUE_NAME , RTEMS_RECORD_THREAD_QUEUE_SURRENDER ,
  RTEMS_RECORD_THREAD_QUEUE_SURRENDER_STICKY , RTEMS_RECORD_THREAD_RESOURCE_OBTAIN , RTEMS_RECORD_THREAD_RESOURCE_RELEASE , RTEMS_RECORD_THREAD_RESTART ,
  RTEMS_RECORD_THREAD_STACK_CURRENT , RTEMS_RECORD_THREAD_STACK_SIZE , RTEMS_RECORD_THREAD_STACK_USAGE , RTEMS_RECORD_THREAD_START ,
  RTEMS_RECORD_THREAD_STATE_CLEAR , RTEMS_RECORD_THREAD_STATE_SET , RTEMS_RECORD_THREAD_SWITCH_IN , RTEMS_RECORD_THREAD_SWITCH_OUT ,
  RTEMS_RECORD_THREAD_TERMINATE , RTEMS_RECORD_THREAD_TIMER_INSERT_MONOTONIC , RTEMS_RECORD_THREAD_TIMER_INSERT_REALTIME , RTEMS_RECORD_THREAD_TIMER_INSERT_TICKS ,
  RTEMS_RECORD_THREAD_TIMER_REMOVE , RTEMS_RECORD_TOOLS , RTEMS_RECORD_UDP_INPUT , RTEMS_RECORD_UDP_OUTPUT ,
  RTEMS_RECORD_UMA_ALLOC_PTR , RTEMS_RECORD_UMA_ALLOC_ZONE , RTEMS_RECORD_UMA_FREE_PTR , RTEMS_RECORD_UMA_FREE_ZONE ,
  RTEMS_RECORD_UNLINK_ENTRY , RTEMS_RECORD_UNLINK_EXIT , RTEMS_RECORD_UNMOUNT_ENTRY , RTEMS_RECORD_UNMOUNT_EXIT ,
  RTEMS_RECORD_UPTIME_HIGH , RTEMS_RECORD_UPTIME_LOW , RTEMS_RECORD_VERSION_CONTROL_KEY , RTEMS_RECORD_WATCHDOG_ADDRESS ,
  RTEMS_RECORD_WATCHDOG_CPU , RTEMS_RECORD_WATCHDOG_INITIALIZE , RTEMS_RECORD_WATCHDOG_INSERT , RTEMS_RECORD_WATCHDOG_PREINITIALIZE ,
  RTEMS_RECORD_WATCHDOG_REMOVE , RTEMS_RECORD_WATCHDOG_ROUTINE , RTEMS_RECORD_WATCHDOG_STATE , RTEMS_RECORD_WORKSPACE_ALLOC_ENTRY ,
  RTEMS_RECORD_WORKSPACE_ALLOC_EXIT , RTEMS_RECORD_WORKSPACE_FREE_ENTY , RTEMS_RECORD_WORKSPACE_FREE_EXIT , RTEMS_RECORD_WORKSPACE_SIZE ,
  RTEMS_RECORD_WORKSPACE_USAGE , RTEMS_RECORD_WRITE_ENTRY , RTEMS_RECORD_WRITE_EXIT , RTEMS_RECORD_WRITEV_ENTRY ,
  RTEMS_RECORD_WRITEV_EXIT , RTEMS_RECORD_SYSTEM_341 , RTEMS_RECORD_SYSTEM_342 , RTEMS_RECORD_SYSTEM_343 ,
  RTEMS_RECORD_SYSTEM_344 , RTEMS_RECORD_SYSTEM_345 , RTEMS_RECORD_SYSTEM_346 , RTEMS_RECORD_SYSTEM_347 ,
  RTEMS_RECORD_SYSTEM_348 , RTEMS_RECORD_SYSTEM_349 , RTEMS_RECORD_SYSTEM_350 , RTEMS_RECORD_SYSTEM_351 ,
  RTEMS_RECORD_SYSTEM_352 , RTEMS_RECORD_SYSTEM_353 , RTEMS_RECORD_SYSTEM_354 , RTEMS_RECORD_SYSTEM_355 ,
  RTEMS_RECORD_SYSTEM_356 , RTEMS_RECORD_SYSTEM_357 , RTEMS_RECORD_SYSTEM_358 , RTEMS_RECORD_SYSTEM_359 ,
  RTEMS_RECORD_SYSTEM_360 , RTEMS_RECORD_SYSTEM_361 , RTEMS_RECORD_SYSTEM_362 , RTEMS_RECORD_SYSTEM_363 ,
  RTEMS_RECORD_SYSTEM_364 , RTEMS_RECORD_SYSTEM_365 , RTEMS_RECORD_SYSTEM_366 , RTEMS_RECORD_SYSTEM_367 ,
  RTEMS_RECORD_SYSTEM_368 , RTEMS_RECORD_SYSTEM_369 , RTEMS_RECORD_SYSTEM_370 , RTEMS_RECORD_SYSTEM_371 ,
  RTEMS_RECORD_SYSTEM_372 , RTEMS_RECORD_SYSTEM_373 , RTEMS_RECORD_SYSTEM_374 , RTEMS_RECORD_SYSTEM_375 ,
  RTEMS_RECORD_SYSTEM_376 , RTEMS_RECORD_SYSTEM_377 , RTEMS_RECORD_SYSTEM_378 , RTEMS_RECORD_SYSTEM_379 ,
  RTEMS_RECORD_SYSTEM_380 , RTEMS_RECORD_SYSTEM_381 , RTEMS_RECORD_SYSTEM_382 , RTEMS_RECORD_SYSTEM_383 ,
  RTEMS_RECORD_SYSTEM_384 , RTEMS_RECORD_SYSTEM_385 , RTEMS_RECORD_SYSTEM_386 , RTEMS_RECORD_SYSTEM_387 ,
  RTEMS_RECORD_SYSTEM_388 , RTEMS_RECORD_SYSTEM_389 , RTEMS_RECORD_SYSTEM_390 , RTEMS_RECORD_SYSTEM_391 ,
  RTEMS_RECORD_SYSTEM_392 , RTEMS_RECORD_SYSTEM_393 , RTEMS_RECORD_SYSTEM_394 , RTEMS_RECORD_SYSTEM_395 ,
  RTEMS_RECORD_SYSTEM_396 , RTEMS_RECORD_SYSTEM_397 , RTEMS_RECORD_SYSTEM_398 , RTEMS_RECORD_SYSTEM_399 ,
  RTEMS_RECORD_SYSTEM_400 , RTEMS_RECORD_SYSTEM_401 , RTEMS_RECORD_SYSTEM_402 , RTEMS_RECORD_SYSTEM_403 ,
  RTEMS_RECORD_SYSTEM_404 , RTEMS_RECORD_SYSTEM_405 , RTEMS_RECORD_SYSTEM_406 , RTEMS_RECORD_SYSTEM_407 ,
  RTEMS_RECORD_SYSTEM_408 , RTEMS_RECORD_SYSTEM_409 , RTEMS_RECORD_SYSTEM_410 , RTEMS_RECORD_SYSTEM_411 ,
  RTEMS_RECORD_SYSTEM_412 , RTEMS_RECORD_SYSTEM_413 , RTEMS_RECORD_SYSTEM_414 , RTEMS_RECORD_SYSTEM_415 ,
  RTEMS_RECORD_SYSTEM_416 , RTEMS_RECORD_SYSTEM_417 , RTEMS_RECORD_SYSTEM_418 , RTEMS_RECORD_SYSTEM_419 ,
  RTEMS_RECORD_SYSTEM_420 , RTEMS_RECORD_SYSTEM_421 , RTEMS_RECORD_SYSTEM_422 , RTEMS_RECORD_SYSTEM_423 ,
  RTEMS_RECORD_SYSTEM_424 , RTEMS_RECORD_SYSTEM_425 , RTEMS_RECORD_SYSTEM_426 , RTEMS_RECORD_SYSTEM_427 ,
  RTEMS_RECORD_SYSTEM_428 , RTEMS_RECORD_SYSTEM_429 , RTEMS_RECORD_SYSTEM_430 , RTEMS_RECORD_SYSTEM_431 ,
  RTEMS_RECORD_SYSTEM_432 , RTEMS_RECORD_SYSTEM_433 , RTEMS_RECORD_SYSTEM_434 , RTEMS_RECORD_SYSTEM_435 ,
  RTEMS_RECORD_SYSTEM_436 , RTEMS_RECORD_SYSTEM_437 , RTEMS_RECORD_SYSTEM_438 , RTEMS_RECORD_SYSTEM_439 ,
  RTEMS_RECORD_SYSTEM_440 , RTEMS_RECORD_SYSTEM_441 , RTEMS_RECORD_SYSTEM_442 , RTEMS_RECORD_SYSTEM_443 ,
  RTEMS_RECORD_SYSTEM_444 , RTEMS_RECORD_SYSTEM_445 , RTEMS_RECORD_SYSTEM_446 , RTEMS_RECORD_SYSTEM_447 ,
  RTEMS_RECORD_SYSTEM_448 , RTEMS_RECORD_SYSTEM_449 , RTEMS_RECORD_SYSTEM_450 , RTEMS_RECORD_SYSTEM_451 ,
  RTEMS_RECORD_SYSTEM_452 , RTEMS_RECORD_SYSTEM_453 , RTEMS_RECORD_SYSTEM_454 , RTEMS_RECORD_SYSTEM_455 ,
  RTEMS_RECORD_SYSTEM_456 , RTEMS_RECORD_SYSTEM_457 , RTEMS_RECORD_SYSTEM_458 , RTEMS_RECORD_SYSTEM_459 ,
  RTEMS_RECORD_SYSTEM_460 , RTEMS_RECORD_SYSTEM_461 , RTEMS_RECORD_SYSTEM_462 , RTEMS_RECORD_SYSTEM_463 ,
  RTEMS_RECORD_SYSTEM_464 , RTEMS_RECORD_SYSTEM_465 , RTEMS_RECORD_SYSTEM_466 , RTEMS_RECORD_SYSTEM_467 ,
  RTEMS_RECORD_SYSTEM_468 , RTEMS_RECORD_SYSTEM_469 , RTEMS_RECORD_SYSTEM_470 , RTEMS_RECORD_SYSTEM_471 ,
  RTEMS_RECORD_SYSTEM_472 , RTEMS_RECORD_SYSTEM_473 , RTEMS_RECORD_SYSTEM_474 , RTEMS_RECORD_SYSTEM_475 ,
  RTEMS_RECORD_SYSTEM_476 , RTEMS_RECORD_SYSTEM_477 , RTEMS_RECORD_SYSTEM_478 , RTEMS_RECORD_SYSTEM_479 ,
  RTEMS_RECORD_SYSTEM_480 , RTEMS_RECORD_SYSTEM_481 , RTEMS_RECORD_SYSTEM_482 , RTEMS_RECORD_SYSTEM_483 ,
  RTEMS_RECORD_SYSTEM_484 , RTEMS_RECORD_SYSTEM_485 , RTEMS_RECORD_SYSTEM_486 , RTEMS_RECORD_SYSTEM_487 ,
  RTEMS_RECORD_SYSTEM_488 , RTEMS_RECORD_SYSTEM_489 , RTEMS_RECORD_SYSTEM_490 , RTEMS_RECORD_SYSTEM_491 ,
  RTEMS_RECORD_SYSTEM_492 , RTEMS_RECORD_SYSTEM_493 , RTEMS_RECORD_SYSTEM_494 , RTEMS_RECORD_SYSTEM_495 ,
  RTEMS_RECORD_SYSTEM_496 , RTEMS_RECORD_SYSTEM_497 , RTEMS_RECORD_SYSTEM_498 , RTEMS_RECORD_SYSTEM_499 ,
  RTEMS_RECORD_SYSTEM_500 , RTEMS_RECORD_SYSTEM_501 , RTEMS_RECORD_SYSTEM_502 , RTEMS_RECORD_SYSTEM_503 ,
  RTEMS_RECORD_SYSTEM_504 , RTEMS_RECORD_SYSTEM_505 , RTEMS_RECORD_SYSTEM_506 , RTEMS_RECORD_SYSTEM_507 ,
  RTEMS_RECORD_SYSTEM_508 , RTEMS_RECORD_SYSTEM_509 , RTEMS_RECORD_SYSTEM_510 , RTEMS_RECORD_SYSTEM_511 ,
  RTEMS_RECORD_USER_0 , RTEMS_RECORD_USER_1 , RTEMS_RECORD_USER_2 , RTEMS_RECORD_USER_3 ,
  RTEMS_RECORD_USER_4 , RTEMS_RECORD_USER_5 , RTEMS_RECORD_USER_6 , RTEMS_RECORD_USER_7 ,
  RTEMS_RECORD_USER_8 , RTEMS_RECORD_USER_9 , RTEMS_RECORD_USER_10 , RTEMS_RECORD_USER_11 ,
  RTEMS_RECORD_USER_12 , RTEMS_RECORD_USER_13 , RTEMS_RECORD_USER_14 , RTEMS_RECORD_USER_15 ,
  RTEMS_RECORD_USER_16 , RTEMS_RECORD_USER_17 , RTEMS_RECORD_USER_18 , RTEMS_RECORD_USER_19 ,
  RTEMS_RECORD_USER_20 , RTEMS_RECORD_USER_21 , RTEMS_RECORD_USER_22 , RTEMS_RECORD_USER_23 ,
  RTEMS_RECORD_USER_24 , RTEMS_RECORD_USER_25 , RTEMS_RECORD_USER_26 , RTEMS_RECORD_USER_27 ,
  RTEMS_RECORD_USER_28 , RTEMS_RECORD_USER_29 , RTEMS_RECORD_USER_30 , RTEMS_RECORD_USER_31 ,
  RTEMS_RECORD_USER_32 , RTEMS_RECORD_USER_33 , RTEMS_RECORD_USER_34 , RTEMS_RECORD_USER_35 ,
  RTEMS_RECORD_USER_36 , RTEMS_RECORD_USER_37 , RTEMS_RECORD_USER_38 , RTEMS_RECORD_USER_39 ,
  RTEMS_RECORD_USER_40 , RTEMS_RECORD_USER_41 , RTEMS_RECORD_USER_42 , RTEMS_RECORD_USER_43 ,
  RTEMS_RECORD_USER_44 , RTEMS_RECORD_USER_45 , RTEMS_RECORD_USER_46 , RTEMS_RECORD_USER_47 ,
  RTEMS_RECORD_USER_48 , RTEMS_RECORD_USER_49 , RTEMS_RECORD_USER_50 , RTEMS_RECORD_USER_51 ,
  RTEMS_RECORD_USER_52 , RTEMS_RECORD_USER_53 , RTEMS_RECORD_USER_54 , RTEMS_RECORD_USER_55 ,
  RTEMS_RECORD_USER_56 , RTEMS_RECORD_USER_57 , RTEMS_RECORD_USER_58 , RTEMS_RECORD_USER_59 ,
  RTEMS_RECORD_USER_60 , RTEMS_RECORD_USER_61 , RTEMS_RECORD_USER_62 , RTEMS_RECORD_USER_63 ,
  RTEMS_RECORD_USER_64 , RTEMS_RECORD_USER_65 , RTEMS_RECORD_USER_66 , RTEMS_RECORD_USER_67 ,
  RTEMS_RECORD_USER_68 , RTEMS_RECORD_USER_69 , RTEMS_RECORD_USER_70 , RTEMS_RECORD_USER_71 ,
  RTEMS_RECORD_USER_72 , RTEMS_RECORD_USER_73 , RTEMS_RECORD_USER_74 , RTEMS_RECORD_USER_75 ,
  RTEMS_RECORD_USER_76 , RTEMS_RECORD_USER_77 , RTEMS_RECORD_USER_78 , RTEMS_RECORD_USER_79 ,
  RTEMS_RECORD_USER_80 , RTEMS_RECORD_USER_81 , RTEMS_RECORD_USER_82 , RTEMS_RECORD_USER_83 ,
  RTEMS_RECORD_USER_84 , RTEMS_RECORD_USER_85 , RTEMS_RECORD_USER_86 , RTEMS_RECORD_USER_87 ,
  RTEMS_RECORD_USER_88 , RTEMS_RECORD_USER_89 , RTEMS_RECORD_USER_90 , RTEMS_RECORD_USER_91 ,
  RTEMS_RECORD_USER_92 , RTEMS_RECORD_USER_93 , RTEMS_RECORD_USER_94 , RTEMS_RECORD_USER_95 ,
  RTEMS_RECORD_USER_96 , RTEMS_RECORD_USER_97 , RTEMS_RECORD_USER_98 , RTEMS_RECORD_USER_99 ,
  RTEMS_RECORD_USER_100 , RTEMS_RECORD_USER_101 , RTEMS_RECORD_USER_102 , RTEMS_RECORD_USER_103 ,
  RTEMS_RECORD_USER_104 , RTEMS_RECORD_USER_105 , RTEMS_RECORD_USER_106 , RTEMS_RECORD_USER_107 ,
  RTEMS_RECORD_USER_108 , RTEMS_RECORD_USER_109 , RTEMS_RECORD_USER_110 , RTEMS_RECORD_USER_111 ,
  RTEMS_RECORD_USER_112 , RTEMS_RECORD_USER_113 , RTEMS_RECORD_USER_114 , RTEMS_RECORD_USER_115 ,
  RTEMS_RECORD_USER_116 , RTEMS_RECORD_USER_117 , RTEMS_RECORD_USER_118 , RTEMS_RECORD_USER_119 ,
  RTEMS_RECORD_USER_120 , RTEMS_RECORD_USER_121 , RTEMS_RECORD_USER_122 , RTEMS_RECORD_USER_123 ,
  RTEMS_RECORD_USER_124 , RTEMS_RECORD_USER_125 , RTEMS_RECORD_USER_126 , RTEMS_RECORD_USER_127 ,
  RTEMS_RECORD_USER_128 , RTEMS_RECORD_USER_129 , RTEMS_RECORD_USER_130 , RTEMS_RECORD_USER_131 ,
  RTEMS_RECORD_USER_132 , RTEMS_RECORD_USER_133 , RTEMS_RECORD_USER_134 , RTEMS_RECORD_USER_135 ,
  RTEMS_RECORD_USER_136 , RTEMS_RECORD_USER_137 , RTEMS_RECORD_USER_138 , RTEMS_RECORD_USER_139 ,
  RTEMS_RECORD_USER_140 , RTEMS_RECORD_USER_141 , RTEMS_RECORD_USER_142 , RTEMS_RECORD_USER_143 ,
  RTEMS_RECORD_USER_144 , RTEMS_RECORD_USER_145 , RTEMS_RECORD_USER_146 , RTEMS_RECORD_USER_147 ,
  RTEMS_RECORD_USER_148 , RTEMS_RECORD_USER_149 , RTEMS_RECORD_USER_150 , RTEMS_RECORD_USER_151 ,
  RTEMS_RECORD_USER_152 , RTEMS_RECORD_USER_153 , RTEMS_RECORD_USER_154 , RTEMS_RECORD_USER_155 ,
  RTEMS_RECORD_USER_156 , RTEMS_RECORD_USER_157 , RTEMS_RECORD_USER_158 , RTEMS_RECORD_USER_159 ,
  RTEMS_RECORD_USER_160 , RTEMS_RECORD_USER_161 , RTEMS_RECORD_USER_162 , RTEMS_RECORD_USER_163 ,
  RTEMS_RECORD_USER_164 , RTEMS_RECORD_USER_165 , RTEMS_RECORD_USER_166 , RTEMS_RECORD_USER_167 ,
  RTEMS_RECORD_USER_168 , RTEMS_RECORD_USER_169 , RTEMS_RECORD_USER_170 , RTEMS_RECORD_USER_171 ,
  RTEMS_RECORD_USER_172 , RTEMS_RECORD_USER_173 , RTEMS_RECORD_USER_174 , RTEMS_RECORD_USER_175 ,
  RTEMS_RECORD_USER_176 , RTEMS_RECORD_USER_177 , RTEMS_RECORD_USER_178 , RTEMS_RECORD_USER_179 ,
  RTEMS_RECORD_USER_180 , RTEMS_RECORD_USER_181 , RTEMS_RECORD_USER_182 , RTEMS_RECORD_USER_183 ,
  RTEMS_RECORD_USER_184 , RTEMS_RECORD_USER_185 , RTEMS_RECORD_USER_186 , RTEMS_RECORD_USER_187 ,
  RTEMS_RECORD_USER_188 , RTEMS_RECORD_USER_189 , RTEMS_RECORD_USER_190 , RTEMS_RECORD_USER_191 ,
  RTEMS_RECORD_USER_192 , RTEMS_RECORD_USER_193 , RTEMS_RECORD_USER_194 , RTEMS_RECORD_USER_195 ,
  RTEMS_RECORD_USER_196 , RTEMS_RECORD_USER_197 , RTEMS_RECORD_USER_198 , RTEMS_RECORD_USER_199 ,
  RTEMS_RECORD_USER_200 , RTEMS_RECORD_USER_201 , RTEMS_RECORD_USER_202 , RTEMS_RECORD_USER_203 ,
  RTEMS_RECORD_USER_204 , RTEMS_RECORD_USER_205 , RTEMS_RECORD_USER_206 , RTEMS_RECORD_USER_207 ,
  RTEMS_RECORD_USER_208 , RTEMS_RECORD_USER_209 , RTEMS_RECORD_USER_210 , RTEMS_RECORD_USER_211 ,
  RTEMS_RECORD_USER_212 , RTEMS_RECORD_USER_213 , RTEMS_RECORD_USER_214 , RTEMS_RECORD_USER_215 ,
  RTEMS_RECORD_USER_216 , RTEMS_RECORD_USER_217 , RTEMS_RECORD_USER_218 , RTEMS_RECORD_USER_219 ,
  RTEMS_RECORD_USER_220 , RTEMS_RECORD_USER_221 , RTEMS_RECORD_USER_222 , RTEMS_RECORD_USER_223 ,
  RTEMS_RECORD_USER_224 , RTEMS_RECORD_USER_225 , RTEMS_RECORD_USER_226 , RTEMS_RECORD_USER_227 ,
  RTEMS_RECORD_USER_228 , RTEMS_RECORD_USER_229 , RTEMS_RECORD_USER_230 , RTEMS_RECORD_USER_231 ,
  RTEMS_RECORD_USER_232 , RTEMS_RECORD_USER_233 , RTEMS_RECORD_USER_234 , RTEMS_RECORD_USER_235 ,
  RTEMS_RECORD_USER_236 , RTEMS_RECORD_USER_237 , RTEMS_RECORD_USER_238 , RTEMS_RECORD_USER_239 ,
  RTEMS_RECORD_USER_240 , RTEMS_RECORD_USER_241 , RTEMS_RECORD_USER_242 , RTEMS_RECORD_USER_243 ,
  RTEMS_RECORD_USER_244 , RTEMS_RECORD_USER_245 , RTEMS_RECORD_USER_246 , RTEMS_RECORD_USER_247 ,
  RTEMS_RECORD_USER_248 , RTEMS_RECORD_USER_249 , RTEMS_RECORD_USER_250 , RTEMS_RECORD_USER_251 ,
  RTEMS_RECORD_USER_252 , RTEMS_RECORD_USER_253 , RTEMS_RECORD_USER_254 , RTEMS_RECORD_USER_255 ,
  RTEMS_RECORD_USER_256 , RTEMS_RECORD_USER_257 , RTEMS_RECORD_USER_258 , RTEMS_RECORD_USER_259 ,
  RTEMS_RECORD_USER_260 , RTEMS_RECORD_USER_261 , RTEMS_RECORD_USER_262 , RTEMS_RECORD_USER_263 ,
  RTEMS_RECORD_USER_264 , RTEMS_RECORD_USER_265 , RTEMS_RECORD_USER_266 , RTEMS_RECORD_USER_267 ,
  RTEMS_RECORD_USER_268 , RTEMS_RECORD_USER_269 , RTEMS_RECORD_USER_270 , RTEMS_RECORD_USER_271 ,
  RTEMS_RECORD_USER_272 , RTEMS_RECORD_USER_273 , RTEMS_RECORD_USER_274 , RTEMS_RECORD_USER_275 ,
  RTEMS_RECORD_USER_276 , RTEMS_RECORD_USER_277 , RTEMS_RECORD_USER_278 , RTEMS_RECORD_USER_279 ,
  RTEMS_RECORD_USER_280 , RTEMS_RECORD_USER_281 , RTEMS_RECORD_USER_282 , RTEMS_RECORD_USER_283 ,
  RTEMS_RECORD_USER_284 , RTEMS_RECORD_USER_285 , RTEMS_RECORD_USER_286 , RTEMS_RECORD_USER_287 ,
  RTEMS_RECORD_USER_288 , RTEMS_RECORD_USER_289 , RTEMS_RECORD_USER_290 , RTEMS_RECORD_USER_291 ,
  RTEMS_RECORD_USER_292 , RTEMS_RECORD_USER_293 , RTEMS_RECORD_USER_294 , RTEMS_RECORD_USER_295 ,
  RTEMS_RECORD_USER_296 , RTEMS_RECORD_USER_297 , RTEMS_RECORD_USER_298 , RTEMS_RECORD_USER_299 ,
  RTEMS_RECORD_USER_300 , RTEMS_RECORD_USER_301 , RTEMS_RECORD_USER_302 , RTEMS_RECORD_USER_303 ,
  RTEMS_RECORD_USER_304 , RTEMS_RECORD_USER_305 , RTEMS_RECORD_USER_306 , RTEMS_RECORD_USER_307 ,
  RTEMS_RECORD_USER_308 , RTEMS_RECORD_USER_309 , RTEMS_RECORD_USER_310 , RTEMS_RECORD_USER_311 ,
  RTEMS_RECORD_USER_312 , RTEMS_RECORD_USER_313 , RTEMS_RECORD_USER_314 , RTEMS_RECORD_USER_315 ,
  RTEMS_RECORD_USER_316 , RTEMS_RECORD_USER_317 , RTEMS_RECORD_USER_318 , RTEMS_RECORD_USER_319 ,
  RTEMS_RECORD_USER_320 , RTEMS_RECORD_USER_321 , RTEMS_RECORD_USER_322 , RTEMS_RECORD_USER_323 ,
  RTEMS_RECORD_USER_324 , RTEMS_RECORD_USER_325 , RTEMS_RECORD_USER_326 , RTEMS_RECORD_USER_327 ,
  RTEMS_RECORD_USER_328 , RTEMS_RECORD_USER_329 , RTEMS_RECORD_USER_330 , RTEMS_RECORD_USER_331 ,
  RTEMS_RECORD_USER_332 , RTEMS_RECORD_USER_333 , RTEMS_RECORD_USER_334 , RTEMS_RECORD_USER_335 ,
  RTEMS_RECORD_USER_336 , RTEMS_RECORD_USER_337 , RTEMS_RECORD_USER_338 , RTEMS_RECORD_USER_339 ,
  RTEMS_RECORD_USER_340 , RTEMS_RECORD_USER_341 , RTEMS_RECORD_USER_342 , RTEMS_RECORD_USER_343 ,
  RTEMS_RECORD_USER_344 , RTEMS_RECORD_USER_345 , RTEMS_RECORD_USER_346 , RTEMS_RECORD_USER_347 ,
  RTEMS_RECORD_USER_348 , RTEMS_RECORD_USER_349 , RTEMS_RECORD_USER_350 , RTEMS_RECORD_USER_351 ,
  RTEMS_RECORD_USER_352 , RTEMS_RECORD_USER_353 , RTEMS_RECORD_USER_354 , RTEMS_RECORD_USER_355 ,
  RTEMS_RECORD_USER_356 , RTEMS_RECORD_USER_357 , RTEMS_RECORD_USER_358 , RTEMS_RECORD_USER_359 ,
  RTEMS_RECORD_USER_360 , RTEMS_RECORD_USER_361 , RTEMS_RECORD_USER_362 , RTEMS_RECORD_USER_363 ,
  RTEMS_RECORD_USER_364 , RTEMS_RECORD_USER_365 , RTEMS_RECORD_USER_366 , RTEMS_RECORD_USER_367 ,
  RTEMS_RECORD_USER_368 , RTEMS_RECORD_USER_369 , RTEMS_RECORD_USER_370 , RTEMS_RECORD_USER_371 ,
  RTEMS_RECORD_USER_372 , RTEMS_RECORD_USER_373 , RTEMS_RECORD_USER_374 , RTEMS_RECORD_USER_375 ,
  RTEMS_RECORD_USER_376 , RTEMS_RECORD_USER_377 , RTEMS_RECORD_USER_378 , RTEMS_RECORD_USER_379 ,
  RTEMS_RECORD_USER_380 , RTEMS_RECORD_USER_381 , RTEMS_RECORD_USER_382 , RTEMS_RECORD_USER_383 ,
  RTEMS_RECORD_USER_384 , RTEMS_RECORD_USER_385 , RTEMS_RECORD_USER_386 , RTEMS_RECORD_USER_387 ,
  RTEMS_RECORD_USER_388 , RTEMS_RECORD_USER_389 , RTEMS_RECORD_USER_390 , RTEMS_RECORD_USER_391 ,
  RTEMS_RECORD_USER_392 , RTEMS_RECORD_USER_393 , RTEMS_RECORD_USER_394 , RTEMS_RECORD_USER_395 ,
  RTEMS_RECORD_USER_396 , RTEMS_RECORD_USER_397 , RTEMS_RECORD_USER_398 , RTEMS_RECORD_USER_399 ,
  RTEMS_RECORD_USER_400 , RTEMS_RECORD_USER_401 , RTEMS_RECORD_USER_402 , RTEMS_RECORD_USER_403 ,
  RTEMS_RECORD_USER_404 , RTEMS_RECORD_USER_405 , RTEMS_RECORD_USER_406 , RTEMS_RECORD_USER_407 ,
  RTEMS_RECORD_USER_408 , RTEMS_RECORD_USER_409 , RTEMS_RECORD_USER_410 , RTEMS_RECORD_USER_411 ,
  RTEMS_RECORD_USER_412 , RTEMS_RECORD_USER_413 , RTEMS_RECORD_USER_414 , RTEMS_RECORD_USER_415 ,
  RTEMS_RECORD_USER_416 , RTEMS_RECORD_USER_417 , RTEMS_RECORD_USER_418 , RTEMS_RECORD_USER_419 ,
  RTEMS_RECORD_USER_420 , RTEMS_RECORD_USER_421 , RTEMS_RECORD_USER_422 , RTEMS_RECORD_USER_423 ,
  RTEMS_RECORD_USER_424 , RTEMS_RECORD_USER_425 , RTEMS_RECORD_USER_426 , RTEMS_RECORD_USER_427 ,
  RTEMS_RECORD_USER_428 , RTEMS_RECORD_USER_429 , RTEMS_RECORD_USER_430 , RTEMS_RECORD_USER_431 ,
  RTEMS_RECORD_USER_432 , RTEMS_RECORD_USER_433 , RTEMS_RECORD_USER_434 , RTEMS_RECORD_USER_435 ,
  RTEMS_RECORD_USER_436 , RTEMS_RECORD_USER_437 , RTEMS_RECORD_USER_438 , RTEMS_RECORD_USER_439 ,
  RTEMS_RECORD_USER_440 , RTEMS_RECORD_USER_441 , RTEMS_RECORD_USER_442 , RTEMS_RECORD_USER_443 ,
  RTEMS_RECORD_USER_444 , RTEMS_RECORD_USER_445 , RTEMS_RECORD_USER_446 , RTEMS_RECORD_USER_447 ,
  RTEMS_RECORD_USER_448 , RTEMS_RECORD_USER_449 , RTEMS_RECORD_USER_450 , RTEMS_RECORD_USER_451 ,
  RTEMS_RECORD_USER_452 , RTEMS_RECORD_USER_453 , RTEMS_RECORD_USER_454 , RTEMS_RECORD_USER_455 ,
  RTEMS_RECORD_USER_456 , RTEMS_RECORD_USER_457 , RTEMS_RECORD_USER_458 , RTEMS_RECORD_USER_459 ,
  RTEMS_RECORD_USER_460 , RTEMS_RECORD_USER_461 , RTEMS_RECORD_USER_462 , RTEMS_RECORD_USER_463 ,
  RTEMS_RECORD_USER_464 , RTEMS_RECORD_USER_465 , RTEMS_RECORD_USER_466 , RTEMS_RECORD_USER_467 ,
  RTEMS_RECORD_USER_468 , RTEMS_RECORD_USER_469 , RTEMS_RECORD_USER_470 , RTEMS_RECORD_USER_471 ,
  RTEMS_RECORD_USER_472 , RTEMS_RECORD_USER_473 , RTEMS_RECORD_USER_474 , RTEMS_RECORD_USER_475 ,
  RTEMS_RECORD_USER_476 , RTEMS_RECORD_USER_477 , RTEMS_RECORD_USER_478 , RTEMS_RECORD_USER_479 ,
  RTEMS_RECORD_USER_480 , RTEMS_RECORD_USER_481 , RTEMS_RECORD_USER_482 , RTEMS_RECORD_USER_483 ,
  RTEMS_RECORD_USER_484 , RTEMS_RECORD_USER_485 , RTEMS_RECORD_USER_486 , RTEMS_RECORD_USER_487 ,
  RTEMS_RECORD_USER_488 , RTEMS_RECORD_USER_489 , RTEMS_RECORD_USER_490 , RTEMS_RECORD_USER_491 ,
  RTEMS_RECORD_USER_492 , RTEMS_RECORD_USER_493 , RTEMS_RECORD_USER_494 , RTEMS_RECORD_USER_495 ,
  RTEMS_RECORD_USER_496 , RTEMS_RECORD_USER_497 , RTEMS_RECORD_USER_498 , RTEMS_RECORD_USER_499 ,
  RTEMS_RECORD_USER_500 , RTEMS_RECORD_USER_501 , RTEMS_RECORD_USER_502 , RTEMS_RECORD_USER_503 ,
  RTEMS_RECORD_USER_504 , RTEMS_RECORD_USER_505 , RTEMS_RECORD_USER_506 , RTEMS_RECORD_USER_507 ,
  RTEMS_RECORD_USER_508 , RTEMS_RECORD_USER_509 , RTEMS_RECORD_USER_510 , RTEMS_RECORD_USER_511
 The record events.
RTEMS_INLINE_ROUTINE void rtems_record_prepare_critical (rtems_record_context *context, const Per_CPU_Control *cpu_self)
 Prepares to add and commit record items in a critical section with interrupts disabled. More...
RTEMS_INLINE_ROUTINE void rtems_record_prepare (rtems_record_context *context)
 Prepares to add and commit record items. More...
RTEMS_INLINE_ROUTINE void rtems_record_add (rtems_record_context *context, rtems_record_event event, rtems_record_data data)
 Adds a record item. More...
RTEMS_INLINE_ROUTINE void rtems_record_commit_critical (rtems_record_context *context)
 Commits a set of record items in a critical section with interrupts disabled. More...
RTEMS_INLINE_ROUTINE void rtems_record_commit (rtems_record_context *context)
 Commits a set of record items. More...
void rtems_record_produce (rtems_record_event event, rtems_record_data data)
 Produces a record item. More...
void rtems_record_produce_2 (rtems_record_event event_0, rtems_record_data data_0, rtems_record_event event_1, rtems_record_data data_1)
 Produces two record items. More...
void rtems_record_produce_n (const rtems_record_item *items, size_t n)
 Produces n record items. More...
void rtems_record_line (void)
 Generates an RTEMS_RECORD_LINE event. More...
void rtems_record_line_2 (rtems_record_event event, rtems_record_data data)
 Generates an RTEMS_RECORD_LINE event and an extra event. More...
void rtems_record_line_3 (rtems_record_event event_0, rtems_record_data data_0, rtems_record_event event_1, rtems_record_data data_1)
 Generates an RTEMS_RECORD_LINE event and two extra events. More...
void rtems_record_line_arg (rtems_record_data data)
 Generates an RTEMS_RECORD_LINE event and one argument event. More...
void rtems_record_line_arg_2 (rtems_record_data data_0, rtems_record_data data_1)
 Generates an RTEMS_RECORD_LINE event and two argument events. More...
void rtems_record_line_arg_3 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2)
 Generates an RTEMS_RECORD_LINE event and three argument events. More...
void rtems_record_line_arg_4 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3)
 Generates an RTEMS_RECORD_LINE event and four argument events. More...
void rtems_record_line_arg_5 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4)
 Generates an RTEMS_RECORD_LINE event and five argument events. More...
void rtems_record_line_arg_6 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5)
 Generates an RTEMS_RECORD_LINE event and six argument events. More...
void rtems_record_line_arg_7 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5, rtems_record_data data_6)
 Generates an RTEMS_RECORD_LINE event and seven argument events. More...
void rtems_record_line_arg_8 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5, rtems_record_data data_6, rtems_record_data data_7)
 Generates an RTEMS_RECORD_LINE event and eight argument events. More...
void rtems_record_line_arg_9 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5, rtems_record_data data_6, rtems_record_data data_7, rtems_record_data data_8)
 Generates an RTEMS_RECORD_LINE event and nine argument events. More...
void rtems_record_line_arg_10 (rtems_record_data data_0, rtems_record_data data_1, rtems_record_data data_2, rtems_record_data data_3, rtems_record_data data_4, rtems_record_data data_5, rtems_record_data data_6, rtems_record_data data_7, rtems_record_data data_8, rtems_record_data data_9)
 Generates an RTEMS_RECORD_LINE event and ten argument events. More...
uint32_t rtems_record_interrupt_disable (void)
 Disables interrupts and generates an RTEMS_RECORD_ISR_DISABLE event. More...
void rtems_record_interrupt_enable (uint32_t level)
 Restores the previous interrupt level and generates an RTEMS_RECORD_ISR_ENABLE event. More...
void _Record_Drain (Record_Control *control, uint32_t cpu_index, rtems_record_drain_visitor visitor, void *arg)
void rtems_record_drain (rtems_record_drain_visitor visitor, void *arg)
 Drains the record items on all processors. More...
void rtems_record_client_init (rtems_record_client_context *ctx, rtems_record_client_handler handler, void *arg)
 Initializes a record client. More...
rtems_record_client_status rtems_record_client_run (rtems_record_client_context *ctx, const void *buf, size_t n)
 Runs the record client to consume new stream data. More...
void rtems_record_client_destroy (rtems_record_client_context *ctx)
 Drains all internal buffers and frees the allocated resources. More...
struct __attribute__ ((__packed__))
 The native record item. More...
const char * rtems_record_event_text (rtems_record_event event)
void rtems_record_dump (rtems_record_dump_chunk chunk, void *arg)
 Dumps the record header, the thread names, and all items of all processors. More...
void rtems_record_dump_base64 (void(*put_char)(int, void *), void *arg)
 Dumps the event records in base64 encoding. More...
void rtems_record_dump_zlib_base64 (rtems_record_dump_base64_zlib_context *ctx, void(*put_char)(int, void *), void *arg)
 Dumps the event records compressed with zlib in base64 encoding. More...
 rtems_record_item
 rtems_record_item_64
◆ rtems_record_caller
#define rtems_record_caller ( )    _Record_Caller( RTEMS_RETURN_ADDRESS() )
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller().
◆ rtems_record_caller_3
#define rtems_record_caller_3 (   event,
  data
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_3().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_3().
Parameters
eventThe record event without a time stamp for the third item.
dataThe record data for the third item.
◆ rtems_record_caller_4
#define rtems_record_caller_4 (   event_0,
  data_0,
  event_1,
  data_1
Value:
_Record_Caller_4( \
event_0, \
data_0, \
event_1, \
data_1 \
#define RTEMS_RETURN_ADDRESS()
Returns the return address of the current function.
Definition: basedefs.h:399
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_4().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_4().
Parameters
event_0The record event without a time stamp for the third item.
data_0The record data for the third item.
event_1The record event without a time stamp for the fourth item.
data_1The record data for the fourth item.
◆ rtems_record_caller_arg
#define rtems_record_caller_arg (   data)     _Record_Caller_arg( RTEMS_RETURN_ADDRESS(), data )
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg().
Parameters
dataThe RTEMS_RECORD_ARG_0 event data.
◆ rtems_record_caller_arg_10
#define rtems_record_caller_arg_10 (   data_0,
  data_1,
  data_2,
  data_3,
  data_4,
  data_5,
  data_6,
  data_7,
  data_8,
  data_9
Value:
_Record_Caller_arg_10( \
data_0, \
data_1, \
data_2, \
data_3, \
data_4, \
data_5, \
data_6, \
data_7, \
data_8, \
data_9 \
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_10().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_10().
Parameters
data_0The RTEMS_RECORD_ARG_0 event data.
data_1The RTEMS_RECORD_ARG_1 event data.
data_2The RTEMS_RECORD_ARG_2 event data.
data_3The RTEMS_RECORD_ARG_3 event data.
data_4The RTEMS_RECORD_ARG_4 event data.
data_5The RTEMS_RECORD_ARG_5 event data.
data_6The RTEMS_RECORD_ARG_6 event data.
data_7The RTEMS_RECORD_ARG_7 event data.
data_8The RTEMS_RECORD_ARG_8 event data.
data_10The RTEMS_RECORD_ARG_10 event data.
◆ rtems_record_caller_arg_2
#define rtems_record_caller_arg_2 (   data_0,
  data_1
Value:
_Record_Caller_arg_2( \
data_0, \
data_1 \
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_2().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_2().
Parameters
◆ rtems_record_caller_arg_3
#define rtems_record_caller_arg_3 (   data_0,
  data_1,
  data_2
Value:
_Record_Caller_arg_3( \
data_0, \
data_1, \
data_2 \
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_3().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_3().
Parameters
◆ rtems_record_caller_arg_4
#define rtems_record_caller_arg_4 (   data_0,
  data_1,
  data_2,
  data_3
Value:
_Record_Caller_arg_4( \
data_0, \
data_1, \
data_2, \
data_3 \
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_4().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_4().
Parameters
◆ rtems_record_caller_arg_5
#define rtems_record_caller_arg_5 (   data_0,
  data_1,
  data_2,
  data_3,
  data_4
Value:
_Record_Caller_arg_5( \
data_0, \
data_1, \
data_2, \
data_3, \
data_4 \
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_5().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_5().
Parameters
◆ rtems_record_caller_arg_6
#define rtems_record_caller_arg_6 (   data_0,
  data_1,
  data_2,
  data_3,
  data_4,
  data_5
Value:
_Record_Caller_arg_6( \
data_0, \
data_1, \
data_2, \
data_3, \
data_4, \
data_5 \
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_6().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_6().
Parameters
◆ rtems_record_caller_arg_7
#define rtems_record_caller_arg_7 (   data_0,
  data_1,
  data_2,
  data_3,
  data_4,
  data_5,
  data_6
Value:
_Record_Caller_arg_7( \
data_0, \
data_1, \
data_2, \
data_3, \
data_4, \
data_5, \
data_6 \
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_7().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_7().
Parameters
◆ rtems_record_caller_arg_8
#define rtems_record_caller_arg_8 (   data_0,
  data_1,
  data_2,
  data_3,
  data_4,
  data_5,
  data_6,
  data_7
Value:
_Record_Caller_arg_8( \
data_0, \
data_1, \
data_2, \
data_3, \
data_4, \
data_5, \
data_6, \
data_7 \
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_8().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_8().
Parameters
◆ rtems_record_caller_arg_9
#define rtems_record_caller_arg_9 (   data_0,
  data_1,
  data_2,
  data_3,
  data_4,
  data_5,
  data_6,
  data_7,
  data_8
Value:
_Record_Caller_arg_9( \
data_0, \
data_1, \
data_2, \
data_3, \
data_4, \
data_5, \
data_6, \
data_7, \
data_8 \
The RTEMS_RECORD_CALLER event data is the return address of the function calling rtems_record_caller_arg_9().
The RTEMS_RECORD_LINE event data is the address of the call to rtems_record_caller_arg_9().
Parameters
◆ rtems_record_entry
#define rtems_record_entry (   event)     rtems_record_produce( event, (rtems_record_data) RTEMS_RETURN_ADDRESS() )
The event data of the specified entry event is the return address of the function calling rtems_record_entry().
Parameters
eventThe entry event.
◆ rtems_record_entry_1
#define rtems_record_entry_1 (   event,
  data
Value:
event, \
RTEMS_RECORD_ARG_0, \
data \
void rtems_record_produce_2(rtems_record_event event_0, rtems_record_data data_0, rtems_record_event event_1, rtems_record_data data_1)
Definition: record.c:56
Definition: recorddata.h:1170
The event data of the specified entry event is the return address of the function calling rtems_record_entry_1().
Parameters
◆ rtems_record_entry_10
#define rtems_record_entry_10 (   event,
  data_0,
  data_1,
  data_2,
  data_3,
  data_4,
  data_5,
  data_6,
  data_7,
  data_8,
  data_9
Value:
_Record_Entry_10( \
event, \
data_0, \
data_1, \
data_2, \
data_3, \
data_4, \
data_5, \
data_6, \
data_7, \
data_8, \
data_9 \
The event data of the specified entry event is the return address of the function calling rtems_record_entry_10().
Parameters
◆ rtems_record_entry_2
#define rtems_record_entry_2 (   event,
  data_0,
  data_1
The event data of the specified entry event is the return address of the function calling rtems_record_entry_2().
Parameters
◆ rtems_record_entry_3
#define rtems_record_entry_3 (   event,
  data_0,
  data_1,
  data_2
Value:
_Record_Entry_3( \
event, \
data_0, \
data_1, \
data_2 \
The event data of the specified entry event is the return address of the function calling rtems_record_entry_3().
Parameters
◆ rtems_record_entry_4
#define rtems_record_entry_4 (   event,
  data_0,
  data_1,
  data_2,
  data_3
Value:
_Record_Entry_4( \
event, \
data_0, \
data_1, \
data_2, \
data_3 \
The event data of the specified entry event is the return address of the function calling rtems_record_entry_4().
Parameters
◆ rtems_record_entry_5
#define rtems_record_entry_5 (   event,
  data_0,
  data_1,
  data_2,
  data_3,
  data_4
Value:
_Record_Entry_5( \
event, \
data_0, \
data_1, \
data_2, \
data_3, \
data_4 \
The event data of the specified entry event is the return address of the function calling rtems_record_entry_5().
Parameters
◆ rtems_record_entry_6
#define rtems_record_entry_6 (   event,
  data_0,
  data_1,
  data_2,
  data_3,
  data_4,
  data_5
Value:
_Record_Entry_6( \
event, \
data_0, \
data_1, \
data_2, \
data_3, \
data_4, \
data_5 \
The event data of the specified entry event is the return address of the function calling rtems_record_entry_6().
Parameters
◆ rtems_record_entry_7
#define rtems_record_entry_7 (   event,
  data_0,
  data_1,
  data_2,
  data_3,
  data_4,
  data_5,
  data_6
Value:
_Record_Entry_7( \
event, \
data_0, \
data_1, \
data_2, \
data_3, \
data_4, \
data_5, \
data_6 \
The event data of the specified entry event is the return address of the function calling rtems_record_entry_7().
Parameters
◆ rtems_record_entry_8
#define rtems_record_entry_8 (   event,
  data_0,
  data_1,
  data_2,
  data_3,
  data_4,
  data_5,
  data_6,
  data_7
Value:
_Record_Entry_8( \
event, \
data_0, \
data_1, \
data_2, \
data_3, \
data_4, \
data_5, \
data_6, \
data_7 \
The event data of the specified entry event is the return address of the function calling rtems_record_entry_8().
Parameters
◆ rtems_record_entry_9
#define rtems_record_entry_9 (   event,
  data_0,
  data_1,
  data_2,
  data_3,
  data_4,
  data_5,
  data_6,
  data_7,
  data_8
Value:
_Record_Entry_9( \
event, \
data_0, \
data_1, \
data_2, \
data_3, \
data_4, \
data_5, \
data_6, \
data_7, \
data_8 \
The event data of the specified entry event is the return address of the function calling rtems_record_entry_9().
Parameters
◆ rtems_record_exit
#define rtems_record_exit (   event)     rtems_record_produce( event, (rtems_record_data) RTEMS_RETURN_ADDRESS() )
The event data of the specified exit event is the return address of the function calling rtems_record_exit().
Parameters
eventThe exit event.
◆ rtems_record_exit_1
#define rtems_record_exit_1 (   event,
  data
Value:
event, \
RTEMS_RECORD_RETURN_0, \
data \
The event data of the specified exit event is the return address of the function calling rtems_record_exit_1().
Parameters
dataThe RTEMS_RECORD_RETURN_0 event data.
◆ rtems_record_exit_10
#define rtems_record_exit_10 (   event,
  data_0,
  data_1,
  data_2,
  data_3,
  data_4,
  data_5,
  data_6,
  data_7,
  data_8,
  data_9
Value:
_Record_Exit_10( \
event, \
data_0, \
data_1, \
data_2, \
data_3, \
data_4, \
data_5, \
data_6, \
data_7, \
data_8, \
data_9 \
The event data of the specified exit event is the return address of the function calling rtems_record_exit_10().
Parameters
data_0The RTEMS_RECORD_RETURN_0 event data.
data_1The RTEMS_RECORD_RETURN_1 event data.
data_2The RTEMS_RECORD_RETURN_2 event data.
data_3The RTEMS_RECORD_RETURN_3 event data.
data_4The RTEMS_RECORD_RETURN_4 event data.
data_5The RTEMS_RECORD_RETURN_5 event data.
data_6The RTEMS_RECORD_RETURN_6 event data.
data_7The RTEMS_RECORD_RETURN_7 event data.
data_8The RTEMS_RECORD_RETURN_8 event data.
data_10The RTEMS_RECORD_RETURN_10 event data.
◆ rtems_record_exit_2
#define rtems_record_exit_2 (   event,
  data_0,
  data_1
The event data of the specified exit event is the return address of the function calling rtems_record_exit_2().
Parameters
◆ rtems_record_exit_3
#define rtems_record_exit_3 (   event,
  data_0,
  data_1,
  data_2
Value:
_Record_Exit_3( \
event, \
data_0, \
data_1, \
data_2 \
The event data of the specified exit event is the return address of the function calling rtems_record_exit_3().
Parameters
◆ rtems_record_exit_4
#define rtems_record_exit_4 (   event,
  data_0,
  data_1,
  data_2,
  data_3
Value:
_Record_Exit_4( \
event, \
data_0, \
data_1, \
data_2, \
data_3 \
The event data of the specified exit event is the return address of the function calling rtems_record_exit_4().
Parameters
◆ rtems_record_exit_5
#define rtems_record_exit_5 (   event,
  data_0,
  data_1,
  data_2,
  data_3,
  data_4
Value:
_Record_Exit_5( \
event, \
data_0, \
data_1, \
data_2, \
data_3, \
data_4 \
The event data of the specified exit event is the return address of the function calling rtems_record_exit_5().
Parameters
◆ rtems_record_exit_6
#define rtems_record_exit_6 (   event,
  data_0,
  data_1,
  data_2,
  data_3,
  data_4,
  data_5
Value:
_Record_Exit_6( \
event, \
data_0, \
data_1, \
data_2, \
data_3, \
data_4, \
data_5 \
The event data of the specified exit event is the return address of the function calling rtems_record_exit_6().
Parameters
◆ rtems_record_exit_7
#define rtems_record_exit_7 (   event,
  data_0,
  data_1,
  data_2,
  data_3,
  data_4,
  data_5,
  data_6
Value:
_Record_Exit_7( \
event, \
data_0, \
data_1, \
data_2, \
data_3, \
data_4, \
data_5, \
data_6 \
The event data of the specified exit event is the return address of the function calling rtems_record_exit_7().
Parameters
◆ rtems_record_exit_8
#define rtems_record_exit_8 (   event,
  data_0,
  data_1,
  data_2,
  data_3,
  data_4,
  data_5,
  data_6,
  data_7
Value:
_Record_Exit_8( \
event, \
data_0, \
data_1, \
data_2, \
data_3, \
data_4, \
data_5, \
data_6, \
data_7 \
The event data of the specified exit event is the return address of the function calling rtems_record_exit_8().
Parameters
◆ rtems_record_exit_9
#define rtems_record_exit_9 (   event,
  data_0,
  data_1,
  data_2,
  data_3,
  data_4,
  data_5,
  data_6,
  data_7,
  data_8
Value:
_Record_Exit_9( \
event, \
data_0, \
data_1, \
data_2, \
data_3, \
data_4, \
data_5, \
data_6, \
data_7, \
data_8 \
The event data of the specified exit event is the return address of the function calling rtems_record_exit_9().
Parameters
◆ RTEMS_RECORD_MAGIC
This is a random number.
◆ RTEMS_RECORD_THE_VERSION
The record version.
The record version reflects the record event definitions. It is reported by the RTEMS_RECORD_VERSION event.
◆ RTEMS_RECORD_TIME_EVENT
#define RTEMS_RECORD_TIME_EVENT (   time,
  event
The events are stored in the record item with a time stamp. There are 22 bits allocated to the time stamp and 10 bits allocated to the event. The 22 bits are enough to get reliable time stamps on a system with a 4GHz CPU counter and a 1000Hz clock tick.
Typedef Documentation
◆ rtems_record_data
It is big enough to store 32-bit integers and pointers.
◆ rtems_record_dump_chunk
Parameters
argThe argument passed to rtems_record_dump().
dataThe begin of the data chunk.
lengthThe length in bytes of the data chunk.
◆ __attribute__()
struct __attribute__ ( (__packed__)  )
The 64-bit format record item.
◆ rtems_record_add()
RTEMS_INLINE_ROUTINE void rtems_record_add ( rtems_record_context context,
Adds a record item.
Parameters
contextThe record context initialized via rtems_record_prepare().
eventThe record event without a time stamp for the item.
dataThe record data for the item.
◆ rtems_record_client_destroy()
void rtems_record_client_destroy ( rtems_record_client_context ctx)
The client context must not be used afterwards. It can be re-initialized via rtems_record_client_init().
Parameters
ctxThe record client context.
◆ rtems_record_client_init()
void rtems_record_client_init ( rtems_record_client_context ctx,
void *  arg
The record client consumes a record item stream produces by the record server.
Parameters
ctxThe record client context to initialize.
handlerThe handler is invoked for each received record item.
argThe handler argument.
◆ rtems_record_client_run()
rtems_record_client_status rtems_record_client_run ( rtems_record_client_context ctx,
const void *  buf,
size_t  n
Parameters
bufThe buffer with new stream data.
nThe size of the buffer.
◆ rtems_record_commit()
RTEMS_INLINE_ROUTINE void rtems_record_commit ( rtems_record_context context)
Parameters
◆ rtems_record_commit_critical()
RTEMS_INLINE_ROUTINE void rtems_record_commit_critical ( rtems_record_context context)
Parameters
contextThe record context initialized via rtems_record_prepare_critical().
◆ rtems_record_drain()
void rtems_record_drain ( rtems_record_drain_visitor  visitor,
void *  arg
Calls the visitor function for each drained item set.
Parameters
visitorThe visitor function.
argThe argument for the visitor function.
◆ rtems_record_dump()
void rtems_record_dump ( rtems_record_dump_chunk  chunk,
void *  arg
Parameters
chunkHandler to dump a chunk of data.
flushHandler to flush the data.
argThe argument for the handlers.
◆ rtems_record_dump_base64()
void rtems_record_dump_base64 ( void(*)(int, void *)  put_char,
void *  arg
Parameters
put_charThe put char handler.
argThe argument for the put char handler.
See also
◆ rtems_record_dump_zlib_base64()
void rtems_record_dump_zlib_base64 ( rtems_record_dump_base64_zlib_context ctx,
void *  arg
Parameters
ctxThe context to perform the record dump with zlib compression and base64 encoding. This context is too large for normal stack sizes.
See also
◆ rtems_record_interrupt_disable()
uint32_t rtems_record_interrupt_disable ( void  )
Returns
The previous interrupt level.
◆ rtems_record_interrupt_enable()
void rtems_record_interrupt_enable ( uint32_t  level)
Parameters
levelThe previous interrupt level. Must be the return value of the corresponding rtems_record_interrupt_disable().
◆ rtems_record_line()
void rtems_record_line ( void  )
The event data is the address of the call to this function.
◆ rtems_record_line_2()
void rtems_record_line_2 ( rtems_record_event  event,
Parameters
eventThe record event without a time stamp for the second item.
dataThe record data for the second item.
◆ rtems_record_line_3()
void rtems_record_line_3 ( rtems_record_event  event_0,
Parameters
event_0The record event without a time stamp for the second item.
data_0The record data for the second item.
event_1The record event without a time stamp for the third item.
data_1The record data for the third item.
◆ rtems_record_line_arg()
void rtems_record_line_arg ( rtems_record_data  data)
The event data of the RTEMS_RECORD_LINE event is the address of the call to this function.
Parameters
◆ rtems_record_line_arg_10()
void rtems_record_line_arg_10 ( rtems_record_data  data_0,
Parameters
data_9The RTEMS_RECORD_ARG_9 event data.
◆ rtems_record_line_arg_2()
void rtems_record_line_arg_2 ( rtems_record_data  data_0,
Parameters
◆ rtems_record_line_arg_3()
void rtems_record_line_arg_3 ( rtems_record_data  data_0,
Parameters
◆ rtems_record_line_arg_4()
void rtems_record_line_arg_4 ( rtems_record_data  data_0,
Parameters
◆ rtems_record_line_arg_5()
void rtems_record_line_arg_5 ( rtems_record_data  data_0,
Parameters
◆ rtems_record_line_arg_6()
void rtems_record_line_arg_6 ( rtems_record_data  data_0,
Parameters
◆ rtems_record_line_arg_7()
void rtems_record_line_arg_7 ( rtems_record_data  data_0,
Parameters
◆ rtems_record_line_arg_8()
void rtems_record_line_arg_8 ( rtems_record_data  data_0,
Parameters
◆ rtems_record_line_arg_9()
void rtems_record_line_arg_9 ( rtems_record_data  data_0,
Parameters
◆ rtems_record_prepare()
RTEMS_INLINE_ROUTINE void rtems_record_prepare ( rtems_record_context context)
This function disables interrupts.
Parameters
contextThe record context which must be used for the following rtems_record_add() and rtems_record_commit() calls. The record context may have an arbitrary content at function entry.
See also
rtems_record_produce().
◆ rtems_record_prepare_critical()
RTEMS_INLINE_ROUTINE void rtems_record_prepare_critical ( rtems_record_context context,
const Per_CPU_Control cpu_self
This function does not disable interrupts. It must be called with interrupts disabled. Interrupts must be disabled until the corresponding rtems_record_commit_critical() was called.
Parameters
contextThe record context which must be used for the following rtems_record_add() and rtems_record_commit_critical() calls. The record context may have an arbitrary content at function entry.
cpu_selfThe control of the current processor.
◆ rtems_record_produce()
void rtems_record_produce ( rtems_record_event  event,
Parameters
◆ rtems_record_produce_2()
void rtems_record_produce_2 ( rtems_record_event  event_0,
Parameters
event_0The record event without a time stamp for the first item.
data_0The record data for the first item.
event_1The record event without a time stamp for the second item.
data_1The record data for the second item.
◆ rtems_record_produce_n()
void rtems_record_produce_n ( const rtems_record_item *  items,
size_t  n
Parameters
itemThe record items without a time stamps.
nThe count of record items.
