BF533 EZ-KIT Board Support Package.
More...
| file | bsp.h |
| | Global BSP definitions.
#define | L1_DATA_SRAM_A 0xff800000L |
| | Blackfin environment memory map.
#define | FIFOLENGTH 0x100 |
void | setLED (uint8_t value) |
| | Helper Function to use the EzKits LEDS. Can be used by the Application.
uint8_t | getLED (void) |
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| | Install an interrupt handler. More...
void | Init_RTC (void) |
void | bfin_null_isr (void) |
PLL configuration for ezkit533
XTL = 27 MHz CLKIN = 13 MHz VCO = 391 MHz CCLK = 391 MHz SCLK = 130 MHz
#define | PLL_CSEL 0x0000 |
| | CCLK = VCO */.
#define | PLL_SSEL 0x0003 |
| | SCLK = CCLK/3 */.
#define | PLL_MSEL 0x3A00 |
| | VCO = 29xCLKIN */.
#define | PLL_DF 0x0001 |
| | CLKIN = XTL/2 */.
#define | CCLK 391000000 |
| | CORE CLOCK */.
#define | SCLK 130000000 |
| | SYSTEM CLOCK */.
#define | BAUDRATE 57600 |
| | Console Baudrate */.
#define | WORD_5BITS 0x00 |
| | 5 bits word */
#define | WORD_6BITS 0x01 |
| | 6 bits word */
#define | WORD_7BITS 0x02 |
| | 7 bits word */
#define | WORD_8BITS 0x03 |
| | 8 bits word */
#define | EVEN_PARITY 0x18 |
| | Enable EVEN parity */.
#define | ODD_PARITY 0x08 |
| | Enable ODD parity */.
#define | TWO_STP_BIT 0x04 |
| | 2 stop bits */
#define | FlashA_PortB_Dir 0x20270007L |
#define | FlashA_PortB_Data 0x20270005L |
#define | RAM_START 0 |
#define | RAM_END 0x100000 |
◆ set_vector()
This method installs an interrupt handle.
- Parameters
| [in] | handler | is the isr routine |
| [in] | vector | is the vector number |
| [in] | type | indicates whether RTEMS or RAW intr |
- Returns
- returns old vector
