RTEMS 5.2
Files | |
| file | partdata.h |
| Classic Partition Manager Data Structures. | |
| file | partimpl.h |
| Classic Partition Manager Implementation. | |
| struct | Partition_Control |
| #define | PARTITION_INFORMATION_DEFINE(max) |
| Macro to define the objects information for the Classic Partition objects. More... | |
| RTEMS_INLINE_ROUTINE void * | _Partition_Allocate_buffer (Partition_Control *the_partition) |
| Allocate a buffer from the_partition. More... | |
| RTEMS_INLINE_ROUTINE void | _Partition_Free_buffer (Partition_Control *the_partition, Chain_Node *the_buffer) |
| Frees the_buffer to the_partition. More... | |
| RTEMS_INLINE_ROUTINE bool | _Partition_Is_buffer_on_boundary (void *the_buffer, Partition_Control *the_partition) |
| Checks whether is on a valid buffer boundary for the_partition. More... | |
| RTEMS_INLINE_ROUTINE bool | _Partition_Is_buffer_valid (Chain_Node *the_buffer, Partition_Control *the_partition) |
| Checks whether the_buffer is a valid buffer from the_partition. More... | |
| RTEMS_INLINE_ROUTINE bool | _Partition_Is_buffer_size_aligned (uint32_t buffer_size) |
| RTEMS_INLINE_ROUTINE bool | _Partition_Is_buffer_area_aligned (const void *starting_address) |
| RTEMS_INLINE_ROUTINE Partition_Control * | _Partition_Allocate (void) |
| Allocates a partition control block from the inactive chain of free partition control blocks. More... | |
| RTEMS_INLINE_ROUTINE void | _Partition_Initialize (Partition_Control *the_partition, void *starting_address, uint32_t length, uint32_t buffer_size, rtems_attribute attribute_set) |
| RTEMS_INLINE_ROUTINE void | _Partition_Destroy (Partition_Control *the_partition) |
| RTEMS_INLINE_ROUTINE void | _Partition_Free (Partition_Control *the_partition) |
| Frees a partition control block to the inactive chain of free partition control blocks. More... | |
| RTEMS_INLINE_ROUTINE Partition_Control * | _Partition_Get (Objects_Id id, ISR_lock_Context *lock_context) |
| RTEMS_INLINE_ROUTINE void | _Partition_Acquire_critical (Partition_Control *the_partition, ISR_lock_Context *lock_context) |
| RTEMS_INLINE_ROUTINE void | _Partition_Release (Partition_Control *the_partition, ISR_lock_Context *lock_context) |
| Objects_Information | _Partition_Information |
| The Classic Partition objects information. | |
| #define PARTITION_INFORMATION_DEFINE | ( | max | ) |
This macro should only be used by <rtems/confdefs.h>.
| max | The configured object maximum (the OBJECTS_UNLIMITED_OBJECTS flag may be set). |
| RTEMS_INLINE_ROUTINE Partition_Control * _Partition_Allocate | ( | void | ) |
This function allocates a partition control block from the inactive chain of free partition control blocks.
| RTEMS_INLINE_ROUTINE void * _Partition_Allocate_buffer | ( | Partition_Control * | the_partition | ) |
This function attempts to allocate a buffer from the_partition. If successful, it returns the address of the allocated buffer. Otherwise, it returns NULL.
| RTEMS_INLINE_ROUTINE void _Partition_Free | ( | Partition_Control * | the_partition | ) |
This routine frees a partition control block to the inactive chain of free partition control blocks.
| RTEMS_INLINE_ROUTINE void _Partition_Free_buffer | ( | Partition_Control * | the_partition, |
| Chain_Node * | the_buffer | ||
This routine frees the_buffer to the_partition.
| RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_on_boundary | ( | void * | the_buffer, |
| Partition_Control * | the_partition | ||
This function returns TRUE if the_buffer is on a valid buffer boundary for the_partition, and FALSE otherwise.
| RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_valid | ( | Chain_Node * | the_buffer, |
This function returns TRUE if the_buffer is a valid buffer from the_partition, otherwise FALSE is returned.
